Release ASUS GT-BE98 Pro Firmware version 3.0.0.6.102_39260 (2026/03/12)
fruitcornbread
Version 3.0.0.6.102_39260
68.74 MB
2026/03/12
Improvements:
Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
Refined accessibility-related UI and interaction details.
Enhanced stability for 2.5G LAN/WAN port operations.
Improved overall remote connection stability.
Improved system behavior when using System diagnostic on feedback page.
Bug Fixes:
Fixed incorrect connection status display for certain Wi-Fi devices.
Fixed AiMesh nodes not displayed correctly in the device list.
Fixed a disconnection issue that occurred after enabling the MAC Filter.
Fixed main network connectivity issue when enabling IPv6 for both the main network and GUEST NETWORK PRO.
Security Enhancements:
Strengthened input sanitization mechanism.
Enhanced system API validation for stronger protection consistency.
Strengthened command handling and system resource access controls.
Improved system logging and security event recording mechanisms.
ZIP SHA-256 : 882BA6B1E8DFE24FAF1C32BAF7E9D0C1B9AA6CEB955AEF95A950186B4FFE750A
FW SHA-256 : 84D6FACC3AD3FE75B7DC37F34D4B7470077F6E293ED09FB295E25B35271CDC9C
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/GT-BE98_Pro/FW_GT-BE98_Pro_300610239260.zip?model=GT-BE98 Pro
(You will need to copy the link and paste it in a browser for the link above to work.)
