Asus n56u recovery mode no open ports to connect
Joey
Hi everybody, I'm new here!
I had an Asus n56u router with the alternative padavan firmware.
After an update - which seemed to went wrong - I couldn't access it anymore, also a reset wasn't possible.
I am able to set it into recovery mode (power light blinking) and connect via LAN to the router.
When I'm scanning for IPs then I can see that the address 192.168.1.1 shows up - as expected.
What I didn't expected is that no port is opened, I scanned for all.
My problem now is, how to I connect/reset to the factory firmware.
Since no port is opened I can't connect, although the IP-address is available
Do I have to connect via some native command and send the firmware directly through an IO-port or something?
Thanks.
