Asus N66U Capped Wired speeds.
Shifty203
Hey all,
I recently got the Asus N66U router, and I am having some troubles with it.
I have a 100 Down / 5 Up Connections here. Usually speedtests at about 88 Megabits. Since I switched to the new router, my download speeds on wired connections cap out at 5 Mb/s. Thats shared across all machines, so 1 Mb/S on 5 machines downloading at once, or 5 Mb/s on one machine downloading.
If I switch to the wifi connection on the same machines, the download speeds increase. Usually cap out at their normal 7-9 Mb/s.
So the problem seems to be the router capping wired connections. I haven't changed any of the stock settings on the router, so QoS is turned off and such.
Any suggestions as to what I can look for?
If I plug my old router back in, I can hit 10 Mb/s over wired.
