Thanks for your reply.
The thread was
Dear all, please tell me if merlin firmware supports NAT LOOPBACK for RT-AC2900(RT-AC86U) If not a new maybe an older. I am not an IT specialist. How i can do this with simple steps if your firmware doesnot support it. Original asus firmware does not support NAT LOOPBACK This is the official...
www.snbforums.com
I have an isp router that has been locked by vodafone and it supports telephony.
So I opened DMZ at this router with host ip the wan ip of an asus RT-AC2900 with the newest firmware Version 3.0.0.4.386.40451
Also i have two different lan
Isp router 192.168.2.1
Asus 192.168.1.1
At asus i also opened, port forward and ddns with noip.
Everything is working perfectly, except for the problem of nat loopback,If nat loopback is indeed the problem.
I cant see the cameras from inside my home, using hostname and wi fi.
I only see cameras from outside my network.
I also tested the Asus newest Merlin firmware,and nothing happened.Then i downgrated at Asus Merlin 384.3 firmware which supported nat loopback and still nothing happened.
The weird thing is that when i test my old router (an ORBI RBR40) in which the company says that it does support loopback, it didnt work either.
Appreciate it a lot, for your time, as i cant seem to find a solution for a while.
