Hello Chaps,
I have had a perfectly working router for a couple of years now not once had any issues with either of the routers connected on my network until I updated he firmware on the RT-AX92U yesterday and now the main router every hour or so will drop the connection all the LED on the from of the router will go out and then reconnection and come back on again. WiFi and LAN connections are all disconnected. and I have absolutely no explanation to why this has happened. I think the firmware update on the other modem on the iMesh is just coincidence. Any help would be deeply appreciated. Because I do not know why after all these years it has been a perfect connection and now all of the sudden it has started to drop all connections including LAN. I can see on the logs when it went offline.
