Asus ROG GS-BE12000 Router
n9nu
Hi
I am assuming this is a rather new unit back from October of 2025 and was wondering if anyone else has this model. It is only $299 at Newegg at present [$399 usually] and just wanted to know if there was any noticeable issues that users encountered.
It is replacing my ROG GT-AX11000 router which I will be selling on the FS thread.
I just needed something with at least one 2.5Gbit or > LAN port and decided to upgrade to a Gen 7 unit. I won't ever be gaming wirelessly..lol. however at $299 it was a much needed upgrade as the GT-AX11000 only has Gbit LAN ports.
I'm looking forward to installing the Merlin firmware on this as well.
Tim
N9NU
Damn. I just looked at the list of compatible units and this one is not Merlin supported...whoops.
Not currently supported by Asus-Merlin nor GNuton fork of Asus-Merlin. There is a separate subforum were BE series routers are being discussed:
Edit to add: And to address the next question that typically will be asked, will Asus-Merlin add support for this model.
[FAQ] READ ME FIRST before posting a question
Q: Will you add support for model XYZ?
A: The decision whether or not to support a new model depend on a long list of factors, which may evolve over time. Right now:
- It needs to be Broadcom-based
- It needs to be widely available (not just in two or three countries)
- It needs to have high-end hardware so I don't have to fight with lack of flash or RAM
- It needs to receive frequent enough GPLs so I won't have to regularly skip it due to the GPL being outdated
- I need to have one
- I need to have the time to try supporting it
- I need to have the motivation to try supporting it
Each new model requires its own dedicated support. That means every time I work on a new firmware release, I have to work on each separate model, and I need GPL releases from Asus for each individual model, and I need to merge each of them separately. So that means if I support 10 different routers, then I need to merge in the content of 10 different GPL releases, and these need to be close enough to one another to still be compatible. The more models I support, the harder this is to accomplish, therefore I am VERY conservative regarding adding any new model.
So don't ask if/when a new model will be supported. I cannot speculate about future model support, and until I have working support for a model, I cannot answer that question.
Yeah I just realized I posted in the FW section and not the BE forum....lol...My bad.
Oh....I wasn't going to ask :) about if/when
I code extensively so I would be up for modding it if need be.
Tim
N9NU
ASUS eStore also has this router on sale. I read your signature, and a GT-AXE16000 has dual 10 Gb Ethernet ports. Probably runs better with your 5 Gbps fiber service. Same price....
As far as I could tell, the GS-BE12000 is the little brother to the GS-BE18000, with the main differences being the GS-BE18000 has 4x4 on the 6GHz band and AFC, whereas the GS-BE12000 lacks AFC and is 2x2 on the 6GHz band. The other specs seem to be the same. I could only find the GS-BE18000 sold in Best Buy in the USA, and the price is $400 on sale now, normally $450, and I think it got as low as $350 during black friday, and you can also use the 15% trade-in discount on it as well I believe.
