Asus ROG GTAC-5300 firmware
TriggerOFAH
Hello I recently upgraded to the ROG gt AC 5300 router but unfortunately there is no firmware .. any chance we could get a firmware for that please ? @RMerlin ... Can't set up my Vpn on seperate devices as I could on the ac86u ... Appreciated if possible mate ... I see the lower version gt ac3200 if am correct was updated .. so fingers crossed we get firmware for the ROG gt AC 5300 .. th
TriggerOFAH
I just googled and from what I read looks like Merlin doesn't support this router .. guess this router was a waste of money then and I will have to go back to ac86u or a better one than ac86u and 1 that's actually supported
unsynaps
There is not much that is better than the AC86U right now unless you NEED Wifi6.
RMerlin
Asuswrt-Merlin dev
VPN Fusion should allow you to route specific clients through the VPN.
TriggerOFAH
Ah I see Vpn fusion now I was too busy lookin at tabs on right side in Vpn section.. not sure how this works though .. easier with your firmware as I learned how to do it in the end.. see what is recommended out of the 2 above if anyone can suggest thanks
RMerlin
Asuswrt-Merlin dev
The RT-AX88U is a much better device than the RT-AC86U, however its price is hard to justify.
TriggerOFAH
Thanks mate I am not happy with this GT ac5300 the range seems quite shirte to be honest .. so may get the ax88u instead then I will get refund from Curry's .. will you be continuing to support it mate as from the look of things in your site seems like he only 1 that isn't updated as a guess with it sayin beta 3 and not 4 like the other models.. if you won't support it then I will have to get the ac86u maybe again
