Asus router as Repeater can't adjust Tx power
gabzprime
I used my n18u as a repeater and I noticed that I can't set Tx power(wireless tab does not appear) when in repeater mode. Is that the same for other Asus router when in repeater mode?
Yes. Repeater mode hides the Professional page in Repeater mode because many of the settings on it can not be applied.
I was asking because I set the TX power at the middle(I think the middle is called balanced) before I turned the router into a repeater. I was wondering if that setting was preserved or it reverted to default(performance).
No idea, the code handling wifi is closed source, so the only way to check is to measure signal strength, and compare.
