Asus router RT-AC86U external drive won't stay mounted after a while
pingoo13
Hello,
I've plugged an external Western Digital G-DRIVE USB 3.0 - 4TB to my Asus RT-AC86U running Asuswrt-Merlin, in order to use it as a media player with UPnP, samba disk and as a time machine backup volume.
This all works well as soon as I plug the disk, but after some time, all the services won't work, it's not just some sleeping mode, it's like the disk has been unplugged. I "only" have to shutdown the hard drive and turn it up again for all the services to be back again properly, which is painful, especially for a service like Time Machine that is running whenever it wants.
I thought it was an OS issue, I've updated to the latest available asuswrt-merlin, but still have the problem.
I'm wondering what going on ? Is there an option on the router somewhere to tell the disk to unmount after a while or something ?
Thanks !
ColinTaylor
Part of the Furniture
Make sure Enable HDD Hibernation is set to No under Administration - System.
bbunge
Hello,
Thanks !
Likely your problem is related to the fact the drive is powered by the router. The AC86U is rated to handle a 4 TB drive but it does not have the power to run one. Since your drive does not have a port for external power you could get a powered USB hub to run the drive. Also, you should have a swap file or partition as your router can run out of RAM when doing SMB file transfer.
pingoo13
Hello, the Western Digital G-DRIVE USB 3.0 - 4TB is actually powered by an external power source, not the USB port.
