1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
ASUS ROUTERS CFE DUMPS COLLECTION
Discussion in 'ASUS Wireless' started by hggomes, Jun 13, 2014.
  1. hggomes
    hggomes Very Senior Member
    Jan 2, 2012
    1,622
    I changed ryzhov_al script and it worked fine for 1.0.1.9, now what i dont get it's this: "cfe_n66u-1.0.1.3.empty.bin" on your 1.0.1.3 script is 131kb and the "cfe_n66u-1.0.1.4.empty.bin" inside your 1.0.1.4 script is 256kb, it matches exactly with the file 1.0.1.4 i have uploaded to you with the XX:XX:XX:XX:XX:XX on the mac addresses.
    I've done the exact same for 1.0.1.9 and it's working fine.
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. hggomes
    Jan 2, 2012
    1,622
    RT-N66U B1 1.0.1.3 and 1.0.1.4 versions were exactly the same on the first post, that's fixed now with a new CFE 1.0.1.3 file upload.
    Thank you to user dextor for finding this issue and reporting it back.
    New RT-AC66R 1.0.1.4 CFE uploaded thanks to user jonaskuh.
  4. Shonk
    Shonk Senior Member
    May 7, 2014
    399
    RT-AC66U 1.0.1.4 EU
    Changed
    et0macaddr=XX:XX:XX:XX:XX:XX
    pci/1/1/macaddr=XX:XX:XX:XX:XX:XX
    pci/2/1/macaddr=XX:XX:XX:XX:XX:XX
    EU secret_code=00000000
    http://pc.cd/o1u
    you should upload all of them to pcloud 4shared requires that you have an account to download most annoying
    are we sure that there's no crc in the image btw?
  5. dextor
    dextor Occasional Visitor
    Jul 23, 2014
    13
    does ryzhov's script insert the correct checksum in the CFE, if it was wrong before upgrading?
  6. ryzhov_al
    ryzhov_al Very Senior Member
    Jul 23, 2012
    646
    Russia
    Yes.
    You may ignore it, a new CRC will be calculated (and embedded) by update script.
  7. hggomes
    Jan 2, 2012
    1,622
    Thank you Shonk for your CFE upload and server change suggestions.
    I have changed the server files to mega.co.cz and added EU and US at each file to better identify it and also replaced ZIP with RAR extension files with a small size. All up to date now :)
  8. Shonk
    Shonk Senior Member
    May 7, 2014
    399
    I have just tried flashing my AC66U with cfe_n66u-1.0.1.9.tgz
    i removed 1.0.1.9.empty.bin just to be safe as i didnt want N66U firmware flashed to it by accident
    anyway i edited my backup to US as i want more than 4 5ghz channels
    and a perm oc -clkfreq=662,331,165
    tried flashing with
    [email protected]:/tmp# ./cfe_update.sh ./cfe.bin
    Current CFE version is 1.0.1.4
    [1/4] Dumping default NVRAM settings from original CFE...
    nvram header found:
    start 0x400
    end 0x1290
    len 3728
    crc 0x52
    ver 0x01
    [2/4] Preparing new CFE...
    cp: can't stat '1.0.1.9.empty.bin': No such file or directory
    can't open file 'cfe.new': No such file or directory
    [3/4] Checking differences between old and new NVRAM areas:
    -bl_version=1.0.1.4
    -boardflags2=0x00000000
    -boardflags=0x00000110
    -boardnum=00
    -boardrev=0x1100
    -boardtype=0xF5B2
    -boot_wait=on
    -bootflags=1
    -et0macaddr=edited out
    -et0mdcport=0
    -et0phyaddr=30
    -gpio4=wps_button
    -gpio7=robo_reset
    -hw_version=1.5
    -lan_ipaddr=192.168.1.1
    -lan_netmask=255.255.255.0
    -landevs=vlan1 wl0 wl1
    -model=RT-AC66U
    -ntype=0
    -odmpid=ASUS
    -pci/1/1/ATE_Brand=ASUSTek
    -pci/1/1/aa2g=7
    -pci/1/1/ag0=0
    -pci/1/1/ag1=0
    -pci/1/1/ag2=0
    -pci/1/1/antswctl2g=0
    -pci/1/1/antswitch=0
    -pci/1/1/boardflags2=0x00100000
    -pci/1/1/boardflags=0x00003200
    -pci/1/1/boardvendor=0x14E4
    -pci/1/1/cckbw202gpo=0x1111
    -pci/1/1/cckbw20ul2gpo=0x1111
    -pci/1/1/ccode=US
    -pci/1/1/devid=0x4332
    -pci/1/1/elna2g=0
    -pci/1/1/extpagain2g=3
    -pci/1/1/ledbh0=2
    -pci/1/1/ledbh12=7
    -pci/1/1/ledbh1=5
    -pci/1/1/ledbh2=4
    -pci/1/1/ledbh3=11
    -pci/1/1/leddc=0xFFFF
    -pci/1/1/legofdm40duppo=0x4444
    -pci/1/1/legofdmbw202gpo=0x74111111
    -pci/1/1/legofdmbw20ul2gpo=0x74111111
    -pci/1/1/macaddr=edited out
    -pci/1/1/maxp2ga0=0x64
    -pci/1/1/maxp2ga1=0x64
    -pci/1/1/maxp2ga2=0x64
    -pci/1/1/mcs32po=0x9999
    -pci/1/1/mcsbw202gpo=0xDA741111
    -pci/1/1/mcsbw20ul2gpo=0xDA741111
    -pci/1/1/mcsbw402gpo=0xFC963333
    -pci/1/1/pa2gw0a0=0xFE74
    -pci/1/1/pa2gw0a1=0xFE85
    -pci/1/1/pa2gw0a2=0xFE75
    -pci/1/1/pa2gw1a0=0x1A2D
    -pci/1/1/pa2gw1a1=0x1C2D
    -pci/1/1/pa2gw1a2=0x1971
    -pci/1/1/pa2gw2a0=0xF999
    -pci/1/1/pa2gw2a1=0xF924
    -pci/1/1/pa2gw2a2=0xF9C8
    -pci/1/1/parefldovoltage=35
    -pci/1/1/pdetrange2g=0
    -pci/1/1/phycal_tempdelta=0
    -pci/1/1/regrev=13
    -pci/1/1/rxchain=7
    -pci/1/1/sromrev=9
    -pci/1/1/tempoffset=0
    -pci/1/1/temps_hysteresis=5
    -pci/1/1/temps_period=5
    -pci/1/1/tempthresh=120
    -pci/1/1/triso2g=3
    -pci/1/1/tssipos2g=1
    -pci/1/1/txchain=7
    -pci/1/1/venid=0x14E4
    -pci/2/1/boardflags2=0x00300002
    -pci/2/1/boardflags3=0x0
    -pci/2/1/boardflags=0x10000000
    -pci/2/1/boardnum=21059
    -pci/2/1/boardrev=0x1305
    -pci/2/1/boardtype=0x621
    -pci/2/1/boardvendor=0x14e4
    -pci/2/1/ccode=US
    -pci/2/1/devid=0x43a2
    -pci/2/1/dot11agduphrpo=0
    -pci/2/1/dot11agduplrpo=0
    -pci/2/1/macaddr=edited out
    -pci/2/1/maxp5ga0=100,100,100,100
    -pci/2/1/maxp5ga1=100,100,100,100
    -pci/2/1/maxp5ga2=100,100,100,100
    -pci/2/1/mcsbw1605ghpo=0
    -pci/2/1/mcsbw1605glpo=0
    -pci/2/1/mcsbw1605gmpo=0
    -pci/2/1/mcsbw205ghpo=0x99753333
    -pci/2/1/mcsbw205glpo=0x99753333
    -pci/2/1/mcsbw205gmpo=0x99753333
    -pci/2/1/mcsbw405ghpo=0x99975333
    -pci/2/1/mcsbw405glpo=0x99975333
    -pci/2/1/mcsbw405gmpo=0x99975333
    -pci/2/1/mcsbw805ghpo=0x99975333
    -pci/2/1/mcsbw805glpo=0x99975333
    -pci/2/1/mcsbw805gmpo=0x99975333
    -pci/2/1/mcslr5ghpo=0
    -pci/2/1/mcslr5glpo=0
    -pci/2/1/mcslr5gmpo=0
    -pci/2/1/pa5ga0=0xff39,0x1a55,0xfcc7,0xff38,0x1a7f,0xfcc3,0xff33,0x1a66,0xfcc4,0xff36,0x1a7b,0xfcc2
    -pci/2/1/pa5ga1=0xff3a,0x1b0b,0xfcba,0xff38,0x1b37,0xfcb4,0xff37,0x1aa1,0xfcc0,0xff37,0x1aef,0xfcb7
    -pci/2/1/pa5ga2=0xff3a,0x1b28,0xfcb4,0xff38,0x1aaa,0xfcc2,0xff35,0x1a93,0xfcc1,0xff38,0x1aab,0xfcbe
    -pci/2/1/regrev=13
    -pci/2/1/rxgains5gelnagaina0=1
    -pci/2/1/rxgains5gelnagaina1=1
    -pci/2/1/rxgains5gelnagaina2=1
    -pci/2/1/rxgains5gtrelnabypa0=1
    -pci/2/1/rxgains5gtrelnabypa1=1
    -pci/2/1/rxgains5gtrelnabypa2=1
    -pci/2/1/rxgains5gtrisoa0=7
    -pci/2/1/rxgains5gtrisoa1=6
    -pci/2/1/rxgains5gtrisoa2=5
    -pci/2/1/sb20in40hrrpo=0
    -pci/2/1/sb20in40lrpo=0
    -pci/2/1/sb20in80and160hr5ghpo=0
    -pci/2/1/sb20in80and160hr5glpo=0
    -pci/2/1/sb20in80and160hr5gmpo=0
    -pci/2/1/sb20in80and160lr5ghpo=0
    -pci/2/1/sb20in80and160lr5glpo=0
    -pci/2/1/sb20in80and160lr5gmpo=0
    -pci/2/1/sb40and80hr5ghpo=0
    -pci/2/1/sb40and80hr5glpo=0
    -pci/2/1/sb40and80hr5gmpo=0
    -pci/2/1/sb40and80lr5ghpo=0
    -pci/2/1/sb40and80lr5glpo=0
    -pci/2/1/sb40and80lr5gmpo=0
    -pci/2/1/venid=0x14e4
    -regulation_domain=US
    -regulation_domain_5G=US
    -sdram_config=0x0000
    -sdram_init=0x0000
    -sdram_ncdl=0x00000000
    -sdram_refresh=0x0000
    -secret_code=edited out
    -serial_no=CAIAA2000001
    -sromrev=8
    -vlan1hwname=et0
    -vlan1ports=1 2 3 4 8*
    -vlan2hwname=et0
    -vlan2ports=0 8u
    -wait_time=3
    -wandevs=et0
    -watchdog=3000
    -xtalfreq=25000
    Something goes wrong, unexpected NVRAM values, exiting...
  9. Pierino
    Pierino Very Senior Member
    Jul 13, 2012
    844
    Columbus Ohio
    I'm not sure you should be putting a cfe for an rt-n66 onto an rt-ac66 but I could be wrong.
  10. Shonk
    Shonk Senior Member
    May 7, 2014
    399
    im not im flashing an edited version of my cfe
  11. hggomes
    Jan 2, 2012
    1,622
    Thats not what you have written, take a look:
    You can edit your own CFE and flash it again, thats not a problem. I've made the same myself to change the default cpu clkfreq.
  12. Shonk
    Shonk Senior Member
    May 7, 2014
    399
    what command did you use
  13. hggomes
    Jan 2, 2012
    1,622
    Talking here could be difficult, take a look at my signature and join in on IRC, we can talk better there and i will try to help.
  14. Shonk
    Shonk Senior Member
    May 7, 2014
    399
    havnt got mirc installed..
    mtd-write -i cfe.bin -d pmon
  15. hggomes
    Jan 2, 2012
    1,622
    Are you sure you've read my signature? You dont need mIRC, its a browser client.
  16. Shonk
    Shonk Senior Member
    May 7, 2014
    399
    Ok i have converted my RT-AC66U from EU to US
    I first tried editing my cfe changing
    clkfreq=662,331,165
    secret_code=my ap pin code
    Resulted in not being able to select 5GHz channels and being forced on 20 MHz so there is clearly something else in the cfe that i didnt change
    So i edited the USA CFE backup to match my device
    clkfreq=662,331,165
    EU secret_code=my ap pin code
    flashed with
    mtd-write -i usacfe.bin -d pmon
    all working fine
    I now have
    Channel 1-11 on 2.4 GHz
    Channel 36 40 44 48 149 153 157 161 on 5 GHz
    Channel: 149/80
    BSSID: EDIT Capability: ESS
    Supported Rates: [ 6(b) 9 12(b) 18 24(b) 36 48 54 ]
    VHT Capable:
    Chanspec: 5GHz channel 155 80MHz (0xe09b)
    Primary channel: 149
  17. hggomes
    Jan 2, 2012
    1,622
    So the first time what MAC adresses have you used on the CFE?
  18. Shonk
    Shonk Senior Member
    May 7, 2014
    399
    Both times my mac address's where used
  19. Shonk
    Shonk Senior Member
    May 7, 2014
    399
  20. hggomes
    Jan 2, 2012
    1,622
    I will add it to the first post.
    Thank you.
  21. oldgringo
    oldgringo Regular Contributor
    Sep 9, 2013
    59
    Is it possible to downgrade CFE to lower version?
