1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
ASUS ROUTERS CFE DUMPS COLLECTION
Discussion in 'ASUS Wireless' started by hggomes, Jun 13, 2014.
  1. hggomes
    hggomes Very Senior Member
    Jan 2, 2012
    1,622
    Yes, its possible CFE downgrade.
  2. Please support SNBForums! Just click on this link before you buy something from Amazon and we'll get a small commission on anything you buy. Thanks!
  3. Pierino
    Pierino Very Senior Member
    Jul 13, 2012
    844
    Columbus Ohio
    Why would you do that?
  4. Techno Pride
    Techno Pride Occasional Visitor
    Jun 7, 2008
    36
    I've exported my router CFE. What utility do I use to make changes?
    Thanks for your help.
  5. hggomes
    Jan 2, 2012
    1,622
    Hexeditor application, try HXD.
  6. philmiami
    philmiami Regular Contributor
    Jun 23, 2014
    163
    earth
    I have the RT-AC68U and just re-checking
    my CFE is the EU version
    but I am in Florida, USA
    Anyway it works....
  7. hggomes
    Jan 2, 2012
    1,622
    No you are wrong, your CFE is US, not EU. Check it again :)
  8. Techno Pride
    Jun 7, 2008
    36
    Thanks! I've already used it to edit the CFE.
    Now I'm trying to use it to flash back to AC66U, following the instructions here:
    http://forums.smallnetbuilder.com/showthread.php?t=8259
    1) downloaded cfe_n66u-1.0.1.9.tgz
    2) edited cfe_update.sh using Win7 Wordpad to remove the CFE version check
    3) placed the modded cfe.old, nvsimple-mipsel and cfe_update.sh into a shared network folder
    4) chmod 777 ./cfe_update.sh
    Then I get
    On a side note, where do you want me to upload the AC56S CFE to? I'll have to edit out some values first.
  9. hggomes
    Jan 2, 2012
    1,622
    Do this before:
    chmod +x cfe_update.sh nvsimple-mipsel
    Update: I noticed you already have done chmod 777 on "cfe_update.sh" file, do the same on "nvsimple-mipsel" and check for correct path.
    Thanks for AC56S CFE, you can upload it to http://tinyupload.com.
  10. Techno Pride
    Jun 7, 2008
    36
    You reckon it's got something to do with Wordpad adding stuff to the end of the file? I vaguely remember some issues with Unix and Windows files when it comes to EOF. The "not found" message only appears when I edit the cfe_update.sh file.
    I'll experiment further. It's bedtime soon.
    Side note:
    AC56S 1.0.2.7 (SG)
    http://s000.tinyupload.com/index.php?file_id=01850622519545044663
  11. hggomes
    Jan 2, 2012
    1,622
    Yeah i noticed that when i was reading again your post, use notepad++ or linux editor like vi.
    Seen the CFE, tks once again.
  12. Techno Pride
    Jun 7, 2008
    36
    Will try to flash the AC66U again this weekend. Asus sold this set in Singapore with US CFE settings...
    BTW, if I simply try to flash without editing the script, it complains about incorrect NVRAM settings. Noted that the script's for N66U. Anything to change to suit AC66U?
    FYI, the sticker on AC56S box states HW Ver A1, comes with firmware 374_4561. It is single-core with 128MB RAM, not AC56U's dualcore and 256MB RAM. The circuit board is different, running on 12v instead of the usual Asus 19v.
  13. hggomes
    Jan 2, 2012
    1,622
    On your CFE i see SG code not US.
    You should edit your AC66U CFE manually instead, that script it's for N66U model, not AC66U.
    Yeah i already knew those about AC56S, tks anyway for info, for instance if you open it please tell please tell me the HW Rev. on PCB.
    Thank you.
  14. Techno Pride
    Jun 7, 2008
    36
    AC66U came with US CFE setting, have to change to SG. This is an official Asus set, not grey market. Have noted that Shonk has posted instructions for a direct flash. Trying to use the script as it apparently adds the CRC value in. Will follow up at IRC at a later date if necessary.
    The AC56S came with correct SG CFE setting.
  15. hggomes
    Jan 2, 2012
    1,622
    I see, but theres no CRC checks so far.
    Oh so originally AC56S CFE was US and you changed it to SG?
  16. philmiami
    Jun 23, 2014
    163
    earth
    I thought 1.0.1.6 was EU?
    whatever...works
    but when I change it to 1100,667 the
    CPU Load Average (1, 5, 15 mins) 0.23, 0.24, 0.16
    changes to quicker
    BUT after a REBOOT when it is at 1100,667 it DEFAULTS back to 800Mhz
  17. philmiami
    Jun 23, 2014
    163
    earth
    I did it at 1100,666 and reboot and it sticks
    CPU Model ARMv7 Processor rev 0 (v7l) - (Cores: 2) CPU Frequency 1100 MHz CPU Load Average (1, 5, 15 mins) 0.60, 0.42, 0.17
    So that still is quicker than 1100,800
    when it is at 1100,666 on CPU load average
  18. RMerlin
    RMerlin Super Moderator
    Apr 14, 2012
    27,099
    Canada
    The only valid CPU and DDR values are as follow (for 802.11ac-capable routers, i.e. that excludes N16/N66):
    static unsigned int cpu_clock_table[] = {600, 800, 1000, 1200, 1400, 1600};
    static unsigned int ddr_clock_table[] = {333, 389, 400, 533, 666, 775, 800};
    Any value not on this list will get downgraded to 800 (CPU) or 533 (DDR).
  19. hggomes
    Jan 2, 2012
    1,622
    Rmerlin, that's not truth on CPU, if you set it to 1100 it will go to next speed (1200mhz) and 1300 will go to 1400 speeds and not to default (800mhz) speed.
    The proof of it its the benchmark results / bogomips.
    http://paste.debian.net/hidden/f769aab0/
  20. RMerlin
    Apr 14, 2012
    27,099
    Canada
    Ok, rectification: Asus will change those to valid clocks if you use the "clkfreq" notification to change clocks (for instance if you were doing it through a web interface). That code doesn't indeed get used automatically at boot time, so manually changing clkfreq will be unaffected by the firmware - only by the CFE itself.
    Nothing in the FW currently uses the clkfreq notification, so I assume it was for an overclocking interface that Asus never finalized.
  21. Techno Pride
    Jun 7, 2008
    36
    hi, the AC56S was already correctly configured for SG.
    It's the AC66U that came with wrong config.
