1. Post filters have been ramped up due to high spam activity. If your post is marked for moderation, be patient. A moderator will review and release it as soon as possible.
    Dismiss Notice
Dismiss Notice
Welcome To SNBForums
ASUS ROUTERS CFE DUMPS COLLECTION
Discussion in 'ASUS Wireless' started by hggomes, Jun 13, 2014.
  1. GoNz0
    GoNz0 Very Senior Member
    Jul 14, 2013
    545
    Do a factory reset after.
    Sent from my SM-G920F using Tapatalk
  2. Vectra
    Vectra Occasional Visitor
    Jun 25, 2017
    12
    What for?
    After downloading the new CFE, the nvram was cleared
  3. GoNz0
    Jul 14, 2013
    545
    Obviously the same purpose.
  4. Vectra
    Jun 25, 2017
    12
    Then I do not understand anything at all :)
    I thought that resetting to factory settings means returning to the memory state with which the router was purchased in the store ... This is a return to the original firmware and bootloader status! Or is it not?
  5. john9527
    john9527 Part of the Furniture
    Mar 28, 2014
    4,889
    United States
    It is NOT....it initializes the nvram state to match that of the CURRENTLY loaded firmware and bootloader. It does not return those to the state as originally shipped.
  6. Vectra
    Jun 25, 2017
    12
    Resetting to the factory settings did not help ... I still watch this picture:
  7. mwnn
    mwnn New Around Here
    Apr 22, 2016
    7
    Just a few quick queries - semi-CFE related - if anyone could confirm my points below:
    > Is it still the case that ASUS (and other brands) have locked all new (and some old) routers from using third-party firmware such as DD-WRT, Tomato, etc? (as a side effect of the FCC/Tx power stuff)
    > I believe certain older models can have their CFE downgraded mostly without risk? (i.e. models on first post - downgrade to 1.0.1.9 CFE or earlier)
    I'm planning on adding an Access Point in a more central location in an old property with solid plastered walls, etc
    This will likely be wired to a hopeless BT Home Hub 6 which has poor range; I could use Repeater Mode at a pinch.
    I won't be picking up a DSL-XXX variant.
    The lady only has horrible ADSL (~4Mb-19Mb)
    I've told her the connection is awful for £40 a month (+ line rental) but she's tied in to it for 12 months.
    On the Openreach site her address is listed as: Pending - EO Line
    So there's no chance of cable/fibre anytime soon apart from with Virgin (they offer 200Mb for £30)
    I've got the choice of handing down my trusty N66U and getting something better for myself or just getting another N66U for cheap off eBay (it worked really well when I tested it yesterday)
    I'm probably best off going with:
    • Another N66U (John F)
    • AC66U (John F / Merlin)
    • Early revision AC68U's (A1, A2, B1)
    Is this all accurate?
    How badly affected is the 2.4Ghz band on the AC68U A1 by having an unshielded USB3 port - I assume it's only when it's in use?
  8. Vectra
    Jun 25, 2017
    12
    I apologize, but I have the impression that my question is either ignored or "uncomfortable" for various reasons to answer!
    If the second, please my mail [email protected] Help, please! Or give a link, who will help ...
  9. Pierino
    Pierino Very Senior Member
    Jul 13, 2012
    807
    Columbus Ohio
    I have an rt-ac66u B1 cfe 1.1.2.0. Not sure if it is encrypted or not and could the rt-ac68u cfe could be flashed, just curious.
    Also I'd read that these had an 800mhz cup but mine is reporting 1ghz.
  10. dlandiss
    dlandiss Senior Member
    Jul 14, 2013
    342
    St. Louis, MO
    Could your issue be the difference between the firmware and the configuration settings?
    Firmware is only changed by flashing, configuration by reset. They are separate memories.
  11. Pierino
    Jul 13, 2012
    807
    Columbus Ohio
    Looks like the cfe for the rt-ac66u B1 is encrypted. I may try to flash one for the rt-ac68p.
  12. Vectra
    Jun 25, 2017
    12
    Describe in detail the order of actions to be performed
  13. GoNz0
    Jul 14, 2013
    545
    Read the manual.
  14. Vectra
    Jun 25, 2017
    12
    Is it difficult for you to write the order of actions?
  15. xdrive55
    xdrive55 New Around Here
    Jul 30, 2017
    1
    remove from cfe territory_code=EE/01 and you will get all channels
    but beter restore original cfe and write Hugo
  16. GoNz0
    Jul 14, 2013
    545
    Couldn't find a definitive answer so i'm going to ask it :)
    The new versions of the AC68, E1 and newer.
    are the CFE's encrypted on those?
    Thanks.
  17. pirx73
    pirx73 Regular Contributor
    Jul 17, 2013
    112
    I have E1 AC68 and i was able to extract CFE, so not encrypted in E1
    GoNz0 likes this.
  18. GoNz0
    Jul 14, 2013
    545
    I think you can dump it but cannot upload it again?
    Assume you're 1ghz?
  19. pirx73
    Jul 17, 2013
    112
    Yes, 1GHz. you can look few pages back and check dump which i linked. It is readable so i assume it was not encrypted.
    GoNz0 likes this.
  20. errorka
    errorka New Around Here
    Aug 19, 2017
    8
    is there any chance to get CFE for rt-ac5300?
Share This Page
