1. Post filters have been ramped up due to high spam activity. If your post is marked for moderation, be patient. A moderator will review and release it as soon as possible.
    Dismiss Notice
Dismiss Notice
Welcome To SNBForums
ASUS ROUTERS CFE DUMPS COLLECTION
Discussion in 'ASUS Wireless' started by hggomes, Jun 13, 2014.
  1. GoNz0
    GoNz0 Very Senior Member
    Jul 14, 2013
    545
    the EU 68u is as follows
  2. Shonk
    Shonk Senior Member
    May 7, 2014
    403
    The AC66U 1.0.1.7 dump doesnt seem complete its only 141,868 bytes
  3. sinshiva
    sinshiva Very Senior Member
    Nov 8, 2013
    1,031
    FL
    when you pull the cfe from mtd0, you also get the trailing whitespace so-to-speak, so this isn't unusual. ryzhov_al spoke of this in his thread
    [edit/] that image was compiled, which is the reason for the difference
  4. hggomes
    hggomes Very Senior Member
    Jan 2, 2012
    1,622
    That's correct.
  5. johnathonm
    johnathonm Occasional Visitor
    Aug 1, 2014
    45
    Does anyone know the regulatory information for SG?
  6. hggomes
    Jan 2, 2012
    1,622
    You can edit the CFE with hexadecimal app and take a look at the CFE.
  7. johnathonm
    Aug 1, 2014
    45
    When editing the CFE what is the best way to overclock the router? I have tried changing the values themselves but it changes the size of the CFE. Please let me know your thoughts.
    Thank you.
  8. Adamm
    Adamm Very Senior Member
    Mar 26, 2013
    1,058
    Do not attempt it as you most certainly will brick the router, overclock via the nvram
  9. hggomes
    Jan 2, 2012
    1,622
    How you edit the file?
  10. johnathonm
    Aug 1, 2014
    45
    Hi all,
    Thank you Adamm for saving me from bricking my router. I thought the speeds were set in the CFE. It can't be done without increasing the file size by 1kb which would brick the router. I opted for a telnet and a cli to solve things.
    J
  11. desiromeo
    desiromeo Occasional Visitor
    Nov 27, 2012
    17
    Hi, I've read the OP but still wanted to ask a question before moving ahead. I have a RT-AC68U with 1.0.1.6 cfe after using the update utility when it was released. I wanted to update to 1.0.2.0 so I am not limited to 666mhz ram and try to overclock slighty higher. Can I use the utility and file to do so? I know there is a risk but, I should only worry if there is some kind of power outage etc. while updating right?
  12. hggomes
    Jan 2, 2012
    1,622
    You will not be able to do it without changing the ASUS Update tool, it will check for 1.0.1.6 CFE and bypass the CFE update.
    You can change that or update via SSH with mtd-write.
  13. desiromeo
    Nov 27, 2012
    17
    Hi hggomes, Im not sure how to change the update tool. I am comfortable with SSH into the router, but I do not have a usb stick connected. Would I be able to transfer the file onto the router somewhere? Also can you explain how to update the cfe with the command?
  14. hggomes
    Jan 2, 2012
    1,622
    Download 1.0.2.0 CFE and change the MAC and regional information of it that matches your original CFE, you can use an hex editor like HXD, after save it and upload the new file to the USB DRIVE and flash it via mtd-write tool.
    In case of doubt please join IRC channel for easier explanation.
  15. hggomes
    Jan 2, 2012
    1,622
    New AC56U 1.0.2.3 (EU) added, thanks to user thaui :)
  16. Builder71
    Builder71 Senior Member
    Oct 14, 2012
    495
    The Netherlands
    Anyone with a link to a cheap ass USB or COM port JTAG interface?
    Preferably known working on a RT-N66U.
    Not that I bricked anything, just for learning purpose and in case of 'oh shit'. :D
  17. hggomes
    Jan 2, 2012
    1,622
  18. Builder71
    Oct 14, 2012
    495
    The Netherlands
    Thx.
    You can also order cables, do you know which one is handy to have?
  19. Vaesel
    Vaesel Occasional Visitor
    Aug 14, 2014
    23
    Bricked AC66U
    Hi
    Just want to let you all know that if you upgrade the cfe to 1.0.1.7 (in this thread) on the AC66U EU (HW 1.30) model, it will brick. Mine is now bricked. I have jtag'it but zJTAG dosent support the flash chip but supports the N66U flash chip and others.
    The others cfe's in this thread for the AC66U works just fine, it was just 1.0.1.7 that bricked it.
    If anyone know how I can unbrick the AC66U, please post how, thanks.
    /Vaesel
  20. hggomes
    Jan 2, 2012
    1,622
    That CFE version (1.0.1.7 US) is working perfectly fine here using the same HW revision.
    Please describe what you have exactly done to have a brick and in what condition is the router when you turn it on.
    NOTE: You should try OpenOCD, if you are expecting to unbrick your router based on zJTAG you will wait for a long time, OpenOCD it's simply the best software for JTAG and it has the BEST SUPPORT TEAM to help with your specific case.
Share This Page
