Asus routers don't do WOL via WAN but Dlink can
dikaiyang
Long story short: Please help.
Dlink DIR-655, WOL works fine over LAN or WAN.
Asus RT-N65U, WOL works on LAN, but for WAN only the first few minutes.
To test I'm not insane, I put DIR-655 behind RT-N65U as a separate subnet and have RT-N65U forward my magic packet through UDP port 9 to DIR-655, then from there to the broadcast address in DIR-655's subnet, WOL works all the time even if the computer has been sleeping for more than minutes.
If I use RT-N65U to forward directly to my computer, from WAN it stops working after a few minutes.
Search suggests setting permanent ARP entry through telnet, which I did, but no change. Note all my devices use static IP already. I don't know why I still need to set static ARP, but I did it anyway.
Is this a shortcoming on Asus routers? So far I have to live with having things that need to be waken on my old DIR-655 in a different subnet behind RT-N65U. The drawback is the NetBIOS name doesn't get passed between the two subnets, only host names. So to access my NAS, I need to use an IP because it only has a NetBIOS name but no host name.
Any suggestions?
Has to do with the Green Ethernet layer 2 of the RT-N56U. Basically, the Asus firmware is not worth it, unless you want Cloud, support I would suggest installing Padavan's firmware. It is one of the best 3rd party projects I have seen in my time for modifying and updating the firmware for a router. It also has WOL support integrated, but you need to VPN first, go to the WOL page within the router, and then you can send a packet via a click of a button. Note that Ai Cloud has that feature too.
It is worth it, you gain better performance, and more functionality out of this 3rd party firmware than the stock firmware, IMO.
http://code.google.com/p/rt-n56u/
Here is Smallnet's forum on the Padavan firmware: http://forums.smallnetbuilder.com/showthread.php?t=7857
It is not Asus' fault, technically speaking. It is the chip used for the layer 2 (switch), a bit of Realtek, their drivers, and Linux all in one.
Interesting. Well if true then it's just a general industry FUBAR situation. Of course it says ASUS on the package so they're accountable if it doesn't work. I was assuming it works on most other routers... do you think that's not the case?
