Asus RP-N12 extender
mcgyver83
Hi all, I have a Fritzbox 7530 as main modem+router and an asus RP-N12 connected via lan cable to connect first floor.
SSID from fritzbox is different than the extender one.
Sometimes I have to physically restart the extender. I loose internet connection (not wifi), I cannot enter the extender web console so I can only reboot it loosing log.
Now I configured remote server log on the extender so I'm not loosing logs.
I'm not having the issue now but I see a lot of "unexpected" log lines from the extender:
Mar 23 07:28:25 192.168.1.2 kernel: 0x6033001C=0xf
Mar 23 07:28:27 192.168.1.2 kernel: 0x60330030=0x2be
Mar 23 07:28:27 192.168.1.2 kernel: 0x6033001C=0xb
Mar 23 07:28:29 192.168.1.2 kernel: 0x60330030=0x447
Mar 23 07:28:29 192.168.1.2 kernel: 0x6033001C=0x12
Mar 23 07:28:31 192.168.1.2 kernel: 0x60330030=0x52f
Mar 23 07:28:31 192.168.1.2 kernel: 0x6033001C=0x9
Mar 23 07:28:34 192.168.1.2 kernel: 0x60330030=0x3ee
Mar 23 07:28:34 192.168.1.2 kernel: 0x6033001C=0x10
Mar 23 07:28:36 192.168.1.2 kernel: 0x60330030=0x4c3
Mar 23 07:28:36 192.168.1.2 kernel: 0x6033001C=0x12
Mar 23 07:28:38 192.168.1.2 kernel: 0x60330030=0x33d
Mar 23 07:28:38 192.168.1.2 kernel: 0x6033001C=0xb
Mar 23 07:28:40 192.168.1.2 kernel: 0x60330030=0x35d
Mar 23 07:28:40 192.168.1.2 kernel: 0x6033001C=0xb
Mar 23 07:28:43 192.168.1.2 kernel: 0x60330030=0x338
Any idea if something is happening?
Hi, did u happen to figure out what was wrong with your repeater?
I have the same model used as an AP for some security cameras and recently it started to lose wifi connection to the cameras (i can still access it through the LAN connection and the log says the exact same thing). After restart it works again... for a while.
I know it's an old post, but maybe u managed to fix it in that time :D
