ASUS RT-AC 1900P multiple IP's with TLS Error handshake failed
dzoker
Can Anyone tell me why I see all these unknown IP's in my log with the TLS Error
ovpn-server1[1196]: XX.XXX.XX.XX:38266 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
ovpn-server1[1196]: XX.XXX.XX.XXX:38266 TLS Error: TLS handshake failed
ovpn-server1[1196]: XX.XXX.XX.XX:44906 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
ovpn-server1[1196]: XX.XXX.XX.XXX:27575 TLS Error: TLS handshake failed
ovpn-server1[1196]: XX.XXX.XX.XX:34539 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
ovpn-server1[1196]: XX.XXX.XX.XXX:21290 TLS Error: TLS handshake failed
also in the VPN section of the router I se 10-15 UNDEF usernames from IP's I don't recognize and with zero bytes sent/received.
I see this all the time in my router log and started couple of weeks ago with no changes from my side
ColinTaylor
Part of the Furniture
Normal port scanning from the internet. Change your VPN server so that it uses a non-standard port.
ColinTaylor
Yes the server port. Choose something random and non-obvious between 5001 and 32767, e.g. 27349.
