ASUS RT-AC1900P Firmware version 3.0.0.4.380.7266
dieter
This version is listed on the Asus website for the RT-AC1900P, but without description of changes. Also, when checking for new firmware from my router, it says that my version 380.4164 is the latest.
How do I know that 380.7266 is the latest released version?
Asus tech support was no help on this...
just means the update server isnt setup yet for the new release , give it a few days
the last part of the numbering system is bigger
release notes are
Bug fixed
- Fixed Android phone tethering mode detecting issue in quick internet setup process.
- Fixed PPPoE related issue.
- Fixed client rename issue in network map.
- Fixed network tool issues.
- Fixed wake on lan issues.
Modification
- Added automatic standby mode for CE Ecodesign directive.
asus pretty much do exactly the same update for all the router models
pete
Sometimes ASUS doesn't list the latest firmware under all the OS options for a while after releasing a new build. I always just look under "Others" instead of something like Win 7 - 64 bit. Usually it's there immediately.
Dieter...curious how you like the 1900P and what you had before. I have the AC-56R which has been good to me, though I'd like better range and throughput on the 5 gHz band. Thanks
I had replied to your post, but it was removed for some reason. I had the DIR655.
