ASUS RT-AC3100 Firmware version 3.0.0.4.385.20490
SwampKracker
- Improved connection stability.
- Optimized CPU utilization.
- Fixed firmware upgrade bugs.
- Fixed CVE-2019-15126 (Kr00k) vulnerability.
- Fixed a DDoS vulnerability.
- Fixed Let's Encrypt related bugs.
- Fixed folder creating bugs in Samba.
- Support router certificate export. After import the certificate to the computer you will not see the warning message when login with https. Please refer to https://www.asus.com/us/support/FAQ/1034294/
Important notice
: If router firmware is 3.0.0.4.385.20490(or newer version) and you want to downgrade to 3.0.0.4.384.81116 (or previous version), you need to reset the router after firmware changed.
Please unzip the firmware file first and then check the MD5 code.
MD5: 5da5492c669853c44e8f521eec5209ff
https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AC3100/FW_RT_AC3100_300438520490.zip
I upgraded to this yesterday and it immediately caused me to lose my WAN connection and was completely unstable. Anyone else notice this?
Just noticed that I can not access the router if it's set to media bridge . it works fine but i can not access wireless
@IAAI, and you shouldn't. Only LAN + WAN ports work in Media Bridge mode. :)
You can access any media bridge configured router for a minimal feature set including admin settings, logs, lan settings, client list and stats, usb applications and network tools
I meant accessing it through the main router
true , the thing is that i find it really difficult to connect to it via the main the router using asus fw .
