ASUS RT-AC3100 Merlin Port Forwarding Issue
Vinh Nguyen
I am trying to view my cameras outside my network. I have a Lorex NVR and have had support assist me and check my DDNS settings and everything looks good. I can't seem to forward any ports on my router though. Using a port checker, it confirms my ports are blocked. Looking for any assistance. Perhaps I have some settings conflicting or something?
Merlin Firmware: 384.15
Note: Some troubleshooting things I've done
  • I tried to turn on DMZ for the NVR but the ports are still blocked.
  • When I enable web access from WAN for the router over 8443, it opens the port and works on WAN.
  • Checked NVRAM - 65704/131072
  • Ensured UPnP is enabled
  • Firewall is enabled
Appreciate any assistance anyone could provide. Thanks in advance.
Make sure your router isn't behind another router, which would block all inbound traffic before it reaches your Asus router.
Doing port scan on the router, i get the below. Think this confirms port fowarding is not happening on the router?
Host is up (0.0086s latency).
Not shown: 50 filtered ports, 45 closed ports
PORT STATE SERVICE
22/tcp open ssh
53/tcp open domain
139/tcp open netbios-ssn
445/tcp open microsoft-ds
9100/tcp open jetdirect
MAC Address: 70:8B:CD:31:B1:18 (Asustek Computer)
Nmap done: 1 IP address (1 host up) scanned in 1.72 seconds
I think he meant port scan the NVR (for ports 80 and 35000), not the router.
I did both but I thought router made more sense. Here is the one for the NVR. Looks like it's open there.
Host is up (0.0043s latency).
Not shown: 97 closed ports
PORT STATE SERVICE
80/tcp open http
443/tcp open https
554/tcp open rtsp
MAC Address: 00:40:7F:B8:14:AC (Flir Systems)
Nmap done: 1 IP address (1 host up) scanned in 0.45 seconds
Can you check port 35000 as well please.
Yes, looks to be open as well. First one was a quick scan and I guess it doesn't scan up to 35000 but an intense scan did.
Scanning 192.168.2.200 [65535 ports]
Discovered open port 443/tcp on 192.168.2.200
Discovered open port 80/tcp on 192.168.2.200
Discovered open port 554/tcp on 192.168.2.200
Discovered open port 8686/tcp on 192.168.2.200
Discovered open port 35000/tcp on 192.168.2.200
Discovered open port 56447/tcp on 192.168.2.200
73.115
Yes it does.
OK, thanks for that. I just wanted to check that you weren't behind some kind of CGNAT.
Well I'm stumped. Your internal scan shows the ports to be listening. Your screenshot in post #1 shows that the ports are forwarded correctly.
I could believe there might be a problem with forwarding port 80 (either with the router or the ISP) but not with ports 554 and 35000.
Have you tested those two ports recently using https://canyouseeme.org/ ? Are they still showing as closed.
Both are still showing up closed. Was thinking about flashing the router back to the default firmware. This bullet gets me though. How does it open and work when the others don't?
The difference between enabling web access (8443) and what you're doing is that 8443 isn't forwarding any ports. The port 8443 service is listening on the router's WAN interface. What you are trying to do is forward traffic from the WAN to the LAN client.
I assume that you aren't using the router's VPN client or server? Your NVR isn't connected to a guest WiFi network or another intermediate router?
Ok, that makes sense.
No, I am not using VPN. The NVR is on the internal network and directly attached to the router (ethernet). Network is pretty straight forward. Cable modem>router>switch.
