Asus RT-AC3200 - No 2.4ghz or 5ghz wireless running.
aggressivesalad
For months the router was working great and was doing well. However today the wireless isn't working, I was using the smart connect.I am able to connect and browse using ethernet meaning that my connection fine and it must be something within the router.
The wireless lights aren't showing on the hardware, however I cannot find anything within the admin panel to enable it. Does anyone have any advise as to what I could do to solve this?
Reboot the router, if that doesn't help next is a to do a factory reset.
Please check wifi scheduling, there are a lot of people facing this issue because of old nvram make wifi scheduling to disable wifi in 2g or 5g, of course, you can do reset to default. Another easy way is to disable wifi scheduling button in wireless -> professional -> wifi scheduling
Thanks,
Vanic
