Asus RT-AC51U support
Hi all, could anyone tell me whether padavans firmware for the AC51U supports selection of devices for VPN? So basically can you select what devices go through VPN and what don't?
I read some where that this was a possibility with some of the custom firmware for routers.
Thanks guys.
I am using the Padavan firmware on my router (RT-AC51U Dual-Band AC750), but Padavan seems to be dead.
There has been no updates for more than 1 1/2 years and Padavan is even confirming "No more updates"
So yes also me I am searching for a Merlin version for my "RT-AC51U Dual-Band AC750"?
Can you help me?
Alltwin
Can you help me?
Alltwin
The answer was given at the start of the thread ........... " NO".
Supported devices are listed here >> http://asuswrt.lostrealm.ca/about
a different question:
I have a USB harddisk (EXT4) on my "RT-AC51U Dual-Band AC750" using transmission (Entware) using Padavan Firmware.
Can I just "connect" this USB hard disk on my RT-AC68U using the Merlin firmware?
Can I then use transmission or do I need to install again transmission through Putty?
Or....do I need to format the USB hard disk, etc.......doing everything again?
Sincerely,
Alltwin
Sincerely,
Alltwin
Hi could please anybody help me with this question on transmission?
In other words if I connect that hard disk to my "Merlin" Asus RT-AC68U, would my transmission still eventhough it was installed on the hard disk using the Padavan firmware on an older Asus router?
If not, what would I need to do being able to get transmission work (hopefully without reformatting the hard disk.
Thank you in advance
Alltwin
