Hi guys,
I tried to flash my Asus RT-AC5300 with Merlin RT-AC3100_380.63_2.trx firmware.
This is the "screen /dev/tty.usbserial 115200" output:
Ctrl+C doesn't work. Reset button doesn't work. Now the router is in a dead loop. What options do I have?
I am ready to solder stuff if it's necessary. Thanx for your help in advance!
Digital core power voltage set to 1.05V
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001EB
000014C0
RDLYW0 00000004
RDENW0 00000039
RDQSW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
WRDQW0
00 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-
WRDMW0 00000023
WRDMW0 00000021
ADDR
00 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++
Decompressing...done
CFE version 7.14.131.1608 (r589038) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
Build Date: Thu Oct 22 17:53:52 CST 2015 (chengche@ubuntu)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1400,*800*
CPU type 0x0: 1400MHz
Tot mem: 524288 KBytes
CFE mem: 0x00F00000 - 0x017A7AE8 (9075432)
Data: 0x00F500A8 - 0x00F505E8 (1344)
BSS: 0x00F505F8 - 0x00FA5AE8 (349424)
Heap: 0x00FA5AE8 - 0x017A5AE8 (8388608)
Stack: 0x017A5AE8 - 0x017A7AE8 (8192)
Text: 0x00F00000 - 0x00F46540 (288064)
Null Rescue Flag.
Hello!! Enter Rescue Mode: (by Force)
Reading ::
TFTP Server.
Failed.: Error
Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: .... 4367776 bytes read
Entry at 0x00008000
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
brd: module loaded
loop: module loaded
pflash: found no supported devices
bcmsflash: found no supported devices
Boot partition size = 524288(0x80000)
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 29
Creating 4 MTD partitions on "nflash":
0x000000000000-0x000000080000 : "boot"
0x000000080000-0x000000200000 : "nvram"
0x000000200000-0x000004000000 : "linux"
0x0000003b61d4-0x000004000000 : "rootfs"
PPP generic driver version 2.4.2
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPTP driver version 0.8.5
=== PPTP init ===
Mirror/redirect action on
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (8047 buckets, 32188 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
L2TP core driver, V2.0
PPPoL2TP kernel driver, V2.0
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
Registering the dns_resolver key type
Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
Spare area=64 eccbytes 56, ecc bytes located at:
2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Available 7 bytes at (off,len):
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Scanning device for bad blocks
Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Creating 1 MTD partitions on "brcmnand":
0x000004000000-0x000008000000 : "brcmnand"
VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
devtmpfs: mounted
Freeing init memory: 288K
## mknod /dev/null: File exists
## mknod /dev/console: File exists
1: set_action 0
Hit ENTER for console...
firmware version: 3.0.0.4.380.63_2
_ifconfig: name=lo flags=1043 IFUP addr=127.0.0.1 netmask=255.0.0.0
route_manip: cmd=ADD name=lo addr=127.0.0.0 netmask=255.0.0.0 gateway=0.0.0.0 metric=0
[1 preinit:init_nvram +9] init_nvram for model(48)
num_of_mssid_support(0x0093): [mssid] support [3] mssid
gmac3_override_nvram
ctf: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
et_module_init: passivemode set to 0x0
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0xce4
et_module_init: et_rxlazy_timeout set to 0x3e8
et_module_init: et_rxlazy_framecnt set to 0x20
et_module_init: et_rxlazy_dyn_thresh set to 0
fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.4402 (r628786)
illegal, cannot enable LACP
config_location(0x003b): [tcode] location is []
config_location(0x003d): [tcode] no location setting, using default location
config_location(0x0053): [tcode] config location: [0:ccode]=[Q2], [0:regrev]=[992]
config_location(0x005d): [tcode] set_wl_country, 0, [Q2], [992]
config_location(0x0073): [tcode] config location 5G: [1:ccode]=[Q2], [1:regrev]=[992]
config_location(0x007e): [tcode] set_wl_country, 1, [Q2], [992]
set_wltxpower(0x023b): unit: 0, txpower: 100
set_wltxpower(0x023b): unit: 1, txpower: 100
hotplug net INTERFACE=fwd1 ACTION=add
hotplug net INTERFACE=fwd0 ACTION=add
hotplug net INTERFACE=dpsta ACTION=add
PCI_PROBE: bus 3, slot 0,vendor 14E4, device 4365(good PCI location)
PCI: Enabling device 0001:03:00.0 (0140 -> 0142)
dhd_attach(): thread:dhd_watchdog_thread:17e started
ring_info_raw: 56
dc 53 3f 00 ac 64 3f 00 c0 66 3f 00 d4 68 3f 00
CUR_ETHERADDR : 6
9c 5c 8e 4b 7f 90
Dongle Host Driver, version 1.369.1 (r628771)
Compiled in drivers/net/wireless/bcmdhd on May 30 2016 at 14:06:44
Register interface [eth0] MAC: 9c:5c:8e:4b:7f:90
PCI_PROBE: bus 4, slot 0,vendor 14E4, device 4365(good PCI location)
PCI: Enabling device 0001:04:00.0 (0140 -> 0142)
hotplug net INTERFACE=eth0 ACTION=add
dhd_attach(): thread:dhd_watchdog_thread:182 started
ring_info_raw: 56
CUR_ETHERADDR : 6
9c 5c 8e 4b 7f 94
Register interface [eth1] MAC: 9c:5c:8e:4b:7f:94
PCI_PROBE: bus 1, slot 0,vendor 14E4, device 4365(good PCI location)
PCI: Enabling device 0002:01:00.0 (0140 -> 0142)
hotplug net INTERFACE=eth1 ACTION=add
dhd_attach(): thread:dhd_watchdog_thread:186 started
Unable to handle kernel paging request at virtual address 60310ef4
pgd = 9dd08000
[60310ef4] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP
last sysfs file: /sys/class/nvram/nvram/dev
module: dhd 7f037000 2898245
module: dpsta 7f031000 2744
module: igs 7f029000 11935
module: emf 7f01e000 21433
module: et 7f00a000 52543
module: ctf 7f000000 19511
Modules linked in: dhd(+) dpsta(P) igs(P) emf(P) et(P) ctf(P)
CPU: 1 Tainted: P (2.6.36.4brcmarm #2)
PC is at _find_first_bit_le+0xc/0x2c
LR is at gic_set_cpu+0x3c/0xb4
pc : [<801767e4>] lr : [<8005ba94>] psr: 00000093
sp : 9dca7d48 ip : 80428a68 fp : 00000000
r10: 00000003 r9 : 7f254968 r8 : a0000013
r7 : 00000008 r6 : f0101000 r5 : 00000000 r4 : 000000a9
r3 : 8043341c r2 : 00000000 r1 : 00000002 r0 : 60310ef4
Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 5dd0804a DAC: 00000015
Process insmod (pid: 380, stack limit = 0x9dca6270)
Stack: (0x9dca7d48 to 0x9dca8000)
7d40: 80415580 804155bc 60310ef4 000000a9 a0000013 800a950c
7d60: 80428a50 80428a20 9a0c0000 9fbdf280 9a0c0000 80215d20 00001894 9fbd0144
[<801767e4>] (PC is at _find_first_bit_le+0xc/0x2c)
Code: eafffff0 e3310000 0a000006 e3a02000 (e7d031a2)
---[ end trace 01fd088b423c40f8 ]---
Kernel panic - not syncing: Fatal exception
[<8005701c>] (unwind_backtrace+0x0/0xf8) from [<8030c6d4>] (panic+0x7c/0x1a8)
[<8030c6d4>] (panic+0x7c/0x1a8) from [<800546f0>] (die+0x1a4/0x1dc)
[<800546f0>] (die+0x1a4/0x1dc) from [<800584b4>] (__do_kernel_fault+0x6c/0x8c)
[<800584b4>] (__do_kernel_fault+0x6c/0x8c) from [<80058624>] (do_page_fault+0x150/0x1ec)
[<80058624>] (do_page_fault+0x150/0x1ec) from [<800503a4>] (do_DataAbort+0x30/0x9c)
[<800503a4>] (do_DataAbort+0x30/0x9c) from [<803d07cc>] (__dabt_svc+0x4c/0x60)
Exception stack(0x9dca7d00 to 0x9dca7d48)
7d00: 60310ef4 00000002 00000000 8043341c 000000a9 00000000 f0101000 00000008
7d20: a0000013 7f254968 00000003 00000000 80428a68 9dca7d48 8005ba94 801767e4
7d40: 00000093 ffffffff
[<803d07cc>] (__dabt_svc+0x4c/0x60) from [<801767e4>] (_find_first_bit_le+0xc/0x2c)
CPU0: stopping
Rebooting in 3 seconds..[<8005701c>] (unwind_backtrace+0x0/0xf8) from [<80050334>] (do_IPI+0x114/0x154)
[<80050334>] (do_IPI+0x114/0x154) from [<803d0840>] (__irq_svc+0x60/0x138)
Exception stack(0x8040ff78 to 0x8040ffc0)
ff60: 00000002 9fa4b900
ff80: 8040ffc0 00000000 8040e000 804330a8 8041ab80 8041ab78 40000000 413fc090
ffa0: 0000001f 00000000 00000000 8040ffc0 80051be4 80051be8 60000013 ffffffff
[<803d0840>] (__irq_svc+0x60/0x138) from [<80051be8>] (default_idle+0x24/0x28)
[<80051be8>] (default_idle+0x24/0x28) from [<80051d88>] (cpu_idle+0x70/0xa4)
[<80051d88>] (cpu_idle+0x70/0xa4) from [<80009134>] (start_kernel+0x3e8/0x450)
[<80009134>] (start_kernel+0x3e8/0x450) from [<40008224>] (0x40008224)
