Dear All Gurus,
I just bought Asus RT-AC5300 and I am not an expert but I have OK knowledge of router setup.
I have couple of questions, any help will be much appreciated.
My setup:
Here is my current setup (please see images below)
(please see attached images below, they will help understand my issues/setup)
Please suggest and review my setup and make your kind suggestions.
I want PS4 gaming to have highest priority over everything.
Thumbnails:
My setup:
- I am using Adaptive QOS
- PS4 has highest priority (connected with LAN port)
- My laptop and TV has medium priority
- All mobiles and tabs have lowest priority
- I have latest Asus firmware on router
- I have DHCP server is set to manual assignment
- My location is India
- Client List is not stable. It sometimes takes a lot of time to display clients which are connected via wifi. Even though 3 clients are connected. It will sometime show 1 or 2 or 3 over a period of 1 minute see attached image
- BandWidth Monitor:
- Does dragging items in list up and down makes a difference? Even though they have prio set. What’s the purpose of sorting items?
- Even though I set Qos to game optimization, DO I still need to set prio in bandwidth monitor. How does it work?
- Is option Respond ICMP Echo (ping) Request from WAN dangerous to turn on ?
- One ps4 , I want to open page http://www.whatsmyip.org/ping and test my ping
- With this option off , I can’t get ping
- Should I keep it on? Is there any other alternative to check ping with this being off ?
- Port Range syntax: is this port range syntax correct?
- PS4 TCP: 3478:3480,80,443,1935
- PS4 UDP: 3478:3479
- Do i need to setup Game Boost WTFast ?? As it supports only limited PS4 games
- Should I put my ps4 in DMZ ?? will it make difference ? I saw few videos which suggest it
- Asus merlin
- Should I Install asus merlin firware. Will it do me any good ?
Thumbnails:
