Asus RT-AC58U V2 - VPN on guest or routing
Bluesobus
Hello everyone,
I'm Arsene, and after a long search on the internet I can't manage to find a solution. So would be nice if someone can give me a hand :)
As mentioned in the title, I'm trying to set up the vpn (openvpn) only on my guest SSID, as I still need the ISP network on SSID1. As I took time looking for a solution, I found the openwrt-Merlin but sadly this firmwares are not compatible with the. RT-AC58U V2.
Is there any artisanal way to do so?
thank for your help.
Seems like a long shot with detours to coding purgatory. :)
The most straightforward way I can think of is to buy an RMerlin supported router and sell the one you have.
Thank you for the answer. Sadly I'm stuck in a foreigner country in Africa, so finding this one was a miracle. :/ got it yesterday ^^.
any advices to do that manually?
Sorry, if I were to try helping in this situation, it would be the blind leading the blind. Others can help, be patient (they may be busy these days with other things).
