Hello guys,
I know this issue has been talked about many times, however I did find some answer but no solution to this issue, so I would need some step by step assistance for a numb like me.
I have a router/modem from my ISP that I can't control anyhow and I connected ASUS RT-AC66U wireless router. I do have a static IP address.
I have a WAN IP obtained from DHCP. The IP address is something like 100.x.x.x
However whastmyip.com showing me my static IP which is 80.x.x.x
However I cannot setup DDNS on my wifi router as it's showing me double NAT issue. When trying to setup DDNS client as asuscomm.com it would connect to 100.x.x.x
Same for the VPN. If setup OpenVPN in wifi router, the .ovpn file configuration will also connect to 100.x.x.x
Shouldn't I connect to IP address 80.x.x.x to get to my home network from outside world?
Would you please someone help me and point me to right direction what I should do to get my DDNS and VPN working. I would like to access my home network from outside for instance security cameras etc.
Thanks for your help,
David
David
