ASUS RT-AC66U Firmware 3.0.0.4.380.3264
rtcomputersinc
Releases note:
ASUS has been dedicated to cooperate with third party developers to come up with more innovative features.
To comply with regulatory amendments, we have modified firmware verification rule to ensure better firmware quality.
This version is not compatible with all previously released ASUS firmware and uncertified third party firmware.
Security Fixed
- Fixed Samba Badlock CVE-2016-2110 (Man in the middle attacks possible with NTLMSSP)
- Fixed Samba Badlock CVE-2016-2111 (NETLOGON Spoofing Vulnerability)
- ASUS firmware did not enable Samba LDAP, and not affected by CVE-2016-2112 (LDAP client and server don't enforce integrity) issue.
- The Samba version in ASUS firmware was not affected by
CVE-2016-2118 (SAMR and LSA man in the middle attacks possible)
CVE-2015-5370 (Multiple errors in DCE-RPC code)
- Fixed command injection issue. Thanks for Chris' contribution.
- Fixed XSS issue. Thanks for Chris' contribution.
Bug Fixed
- Fixed Windows Radius server compatibility issues.
- Fixed 5G performance issue when using bandwidth monitor.
- Fixed bandwidth monitor incorrect number problem.
- Fixed setup wizard redirect issue when router automatically changed LAN IP in IP conflict case.
- Modified setup wizard process when router detected DHCP and PPPoE at the same time.
- Fixed bandwidth limiter bug when there are multiple clients in rule list.
- Fixed NTP automatically sync issue when router rebooted
- Fixed Safari slow response issue.
- Enhance AiCloud dynamic stream port mechanism (please also keep AiCloud app up to date)
- Fixed AiCloud share link related issues.
Releases note:
(Bold mine).
Is this the beginning of the end? Will flashing this firmware effectively block us from flashing back to a previous firmware?
If so, it should be (more) clearly stated.
If not; still a little scary to see (not is USA).
That sounds like the case be very carful flashing this build because it's very likely there will be nothing to go back to if there are issues. Asus will be doing this to all supported routers very soon likely by the end of June so flash at your own risk. o_O:(
It is the non-reversible one. Well unless you put router into restore firmware mode and you can reverse it all day long. :) I tested with the current restore software and restored back to 378.9459 fw but that may change in the future.
What I can also tell you is that my UML290 usb aircard still DOESNT WORK in the latest fw. I had to go back to a firmware that came out over 5 MONTHS AGO because the past 3 versions BREAK the rollover. Its been reported for months now and still not fixed.
