My Apple TM is about to retire due to random restarts after 5 years of service.
I know the Netgear is a better router, but is it worth the extra money over the Asus?
Are you talking about the RT-AC66U, or the RT-AC66U_B1? Cause the RT-AC66U is a 5 years old model, and is nowhere near the performance level of the R7800. The RT-AC66U_B1 has more modern hardware and software, and is more or less identical to the Netgear R7000.
Asus’ lineup is a bit confusing but I think I’m looking at the latest, AC66U B1.
Hard to tell from the online retailers’ listings. Is the B1 the one with the front USB port?
That's correct. Usually, it should be part of the model name, but if it's not a major retailer they might not be properly listing it. If the photo can be trusted, the B1 does have a front USB port, and non-detachable antennas.
That model would be a step behind the R7800, but not that far behind. The RT-AC66U_B1 is quite aggressively priced, and for most users it's more than sufficient.
Thanks for the info!
I just found out the B1 is not wall mountable. A shame.
Welcome To SNBForums
