Asus RT-AC66U with merlin - isolated LAN port 3 with WIFI
akar
Hi all,
I’m trying to set up the RT-AC66U ( merlin 386.1_beta3 ) in a following mode :
WAN port is used for getting the internet ( ip range starting with 88* received via DHCP from WAN )
ASUS LAN DHCP IP range is 10.*
LAN port 1 is used for the Dell server IDRAC ( dhcp address within LAN DHCP – 10.*)
LAN port 2 is used for the KVM server ( dhcp address within LAN DHCP – 10.*)
LAN port 3 port should be used as an isolated bridge/vlan with WIFI 2,4GHz. The LAN port 3 cable is plugged to pFSense server ( where is running DHCP server with IP range 192* ) . The main goal is that WIFI clients get the IP range 192* and will be isolated from the network 10.*
See configuration picture below :
#Remove the LAN 3 port from default VLAN
robocfg vlan 1 ports "1 2 4 5t"
Create a new VLAN 10 where the port 3
robocfg vlan 10 ports "3 5t"
Remove the eth1 ( wifi 2.4g ) from default bridge
brctl delif br0 eth1
#Add the eth1 ( wifi 2.4g ) to newly created VLAN
vconfig add eth1 10
#Create a new bridge br1_pf
brctl addbr br1_pf
#Add a eth1 to new bridge
brctl addif br1_pf eth1
#Add a bridge br1_pf to vlan10
brctl addif br1_pf vlan10
#Enable Wifi 2.4 Ghz
ifconfig eth1 up
If I connect to 2.4Ghz – no IP range is assigned from the DHCP pool 192*
Do you know if is possible to use the bridge/LAN on Asus router for mentioned usage case? If yes, what is missing in my configuration?
Thank you for any kind of help
