ASUS RT-AC68R and OVPN @ 2048 cipher.
What I have.
NP++ (Notepad ++)
ASUS RT-AC68R Merlin 3.0.0.4.374.39
Open VPN for Android 0.6.11
openvpn-install-2.3.4-I001-i686
Samsung Galaxy S5 (ATT)
How I did it.
Install OVPN for Android to my phone.
Install Openvpn-Install 32 bit on my system to create the 2048 certs needed.
Followed http://www.howtogeek.com/60774/connect-to-your-home-network-from-anywhere-with-openvpn-and-tomato/ so I know how to create the certs but editing the vars.bat to 2048.
Created the needed certs, CA, Client, Server and DH.
ASUS RT-AC68R Merlin 3.0.0.4.374.39 settings for OVPN server 1
Note: I do not have any port forwarding or other configs, its pretty much stock as far as configs. Just increased security settings.
I am using DDNS.
OVPN server 1 settings.
Interface: TUN
Protocal: TCP
Port: 1194
Firewall: Auto
Auth: TLS (So I can add the cert stuff)
User Name and PW: NO
Extra HMAC: Disable
VPN Subnet: Default settings
Poll Interval: 0
Push to LAN: Yes
Direct clients to redirect: No
Respond to DNS: No
Encryption Cipher: AES-256-CBC
Compression: None
TLS: -1
Manage Client options: No
Custom Config: Blank.
Now, Once you create your certs, put the cert into in to the ‘Content modification of Keys & Certificates.’ For each cert. and save it (Note: I have no formal training on this stuff and I was able to figure it out)
Now start the VPN client and click on the Export button, this will give you a partial cert with the CA credentials already populated. You just need to populate the rest, use NP++ for this.
Trust me, it’s easy.
I found OVPN for android client has settings you can check that will force all traffic over the tunnel.
Now I can safely browse the internet from any unsecured wifi knowing that all traffic is going form my phone to my asus then to the internet via a VPN @ 2048 cipher.
Like I stated, I have no training so I did the poor man’s test and blocked t.msn.com and I could not access it with the VPN turned on.
Anyone willing to show me some commands real time I can use on the ASUS to show traffic and urls if that’s possible from the TOOLS > Run CMD for real time traffic?
What I have.
NP++ (Notepad ++)
How I did it.
I am using DDNS.
Interface: TUN
Protocal: TCP
Port: 1194
Firewall: Auto
Extra HMAC: Disable
Poll Interval: 0
Push to LAN: Yes
Respond to DNS: No
Compression: None
TLS: -1
