Asus RT-AC68U Firmware Upgrade Problems
Alex31
Hello,
I installed 376-49_5 on my router the thing i have is random disconnect on wifi
So i want to install te last firmware 378.56_2
I did a factory reset then i load the new firmware ok so far so good the router went back online and still i have the old firmware, i did reboot the router and still the old firmware?
Hope someone could help me please.......
You need to install 378.50 first (I think that's the one, not really sure), then latest.
Poslano sa mog SM-G925F koristeći Tapatalk
Actually you should install 378.55 first and after that install newer ones.
You cannot upgrade directly due to fact, that Asus has changed partition layout meanwhile by resizing rootfs.
It will upgrade bootloader as well, after that you can upgrade to the latest.
Thanks Guys,
That was the trick :)
But i did not do a factory default after flashing to 55......
I flashed the latest firmware directly after that, then i reboot and everything works fine so it seems
Hi Guys I have been trying to upgrade firmware to Merlin from the current Asus stock firmware. Followed all the links but have no choose file option under Administration/firmware upgrade. Thanks in advance and sincere apologies if this is posted in the wrong place . Forgive me I'm a Newbie
Have you cleared cache or tried a different browser?
Tried different Browser but not cleared cache
Yes tried that. The issue is there is no choose file option at all simply an check update
Strange, you could also try the firmware recovery tool.
Recent Asus firmware changed the Firmware update page, due to AiMesh. You have to use the "upload" link next to your router model on that page.
