Asus RT-AC68U problem internet radio
helio58
Asus RT-AC68U with merlin RT_AC68U_3.0.0.4_374_35_4
Computer connect to wifi.
When listen internet radio randomly get the stream buffering ,
The only way to continue listing is reopening the bowser.
Have try with Safari and Chrome.
Wired connection have no issue.
Have visit a friend that have a RT-N16
No problem with the stream.
Is there a setting I missed ?
Video works without issues
Originally Posted by RMerlin View Post
RT-AC68U owners, can you give this 374.37_2 test build a shot?
https://www.mediafire.com/folder/ftf9kjixr1a5f//Misc
I only integrated the updated CTF and wireless drivers in it so I could flash it on my main router and give it a more thorough test, but I thought I'd push this to Mediafire for others to try out.
try this one from merlin
Sorry I should explain at the beginning
Running Macbook Mavericks
After lots f testing, this is not a asus issue.
Must be the iOS Mavericks .
Running windows 8.1 on same mac no problems.
Thanks chercm for taking your time.
Someone else recently posted a thread on the forums about issues he had with his router and his Maverick-based Macbook. It seems to be an issue with Maverick.
He posted a workaround that he managed to implement - try to find the thread, it's about a week or two old.
I try to search but haven't found will continue to try to find the post.
I have been using mavericks and I updated to the 37_2 and have not had any issue from then.
Just to add I am using iMac 2010 model
Have it running without problem for the last week.
What I did was increasing the Tx power setting on the 5GHZ to 200mW
I have a cooling fan near the router. No temperatur increase on cpu.
