Asus RT-AC68U remote on Asus app. WAN-connection?
xlarge
My remote router often fails and I'll try the asus app, but the app can't find the router (as it not on same network). Reading a lot (google) about the app and install, but nothing about remote adding a router. One mention security with open WAN. Must I use this or can I add the router via ip and openvpn?
Using a VPN is better than enabling remote access via the app. You will need to set up DDNS. Asus InstantGuard works or OpenVPN. I have used OpenVPN to manage Asus routers remotely for years. However, if the router fails you may not be able to connect to it.
Thanks, but.
The use of asus router app is to manage (reach) the router when the OpenVPN connection is lost. I need both because the OpenVPN fails most of the day.
