ASUS RT-AC68U & VPN Troubles
moccajava
Hi there,
Currently using the latest firmware v380.61.
I am running the OpenVPN server and found a peculiar issue.
The list of users appears to have one row that cannot be deleted and password is blank.
Is this a bug? Any workaround to remove this row and start again from the UI to add new users?
I've tried adding other users first but there is no "minus sign" for the that persistent first row.
Another problem I have is on successful VPN connection to local LAN, it is showing the subnet/mask as defined under "Advanced Settings" (10.8.0.0). I would like to know how the connected IP can have the same IP range as my local LAN, per the DHCP server on the router. Current range is 192.168.0.1-192.168.0.255. Ideally, to control maybe the last 5 IP addresses for VPN (i.e. x.250 - x.254).
Thanks!
If you are talking about the admin user, that user is hardcoded and cannot be removed or disabled.
