Asus RT-AC86U and Debian Bullseye + Nextcloud
chavo
1) install entware
2)enable swap
swapon /opt/swap
3)
opkg install debootstrap binutils
/tmp/mnt/asus - usb disk
debootstrap --arch=arm64 bullseye /opt/debian/ http://ftp.debian.org/debian/
/opt/sbin/debootstrap: line 467: command: not found
/opt/sbin/debootstrap: line 611: can't create /opt/debian/test-dev-null: Permission denied
E: Cannot install into target '/opt/debian' mounted with noexec or nodev
mount -i -o remount,exec,dev /tmp/mnt/asus
mv /opt/etc/init.d/S99debian /opt/etc/
cat >> /opt/etc/init.d/S99debian << 'EOF'
#!/bin/sh
PATH=/opt/bin:/opt/sbin:/sbin:/bin:/usr/sbin:/usr/bin
# Folder with Debian Jessie
CHROOT_DIR=/tmp/mnt/sda1/entware/debian
# Some folder outside of sandbox,
# will be mounted to /mnt folder in Debian
# Uncommented "EXT_DIR=" line if you need to
# mount a folder inside debian (remove #)
# EXT_DIR=/tmp/mnt/sda1/Media/
CHROOT_SERVICES_LIST=/opt/etc/chroot-services.list
if [ ! -e "$CHROOT_SERVICES_LIST" ]; then
    echo "Please, define Debian services to start in $CHROOT_SERVICES_LIST first!"
    echo "One service per line. Hint: this is a script names from Debian's /etc/init.d/"
    exit 1
fi
MountedDirCount="$(mount | grep $CHROOT_DIR | wc -l)"
start() {
    if [ $MountedDirCount -gt 0 ]; then
        echo "Chroot'ed services seems to be already started, exiting..."
        exit 1
    fi
    echo "Starting chroot'ed Debian services..."
    for dir in dev proc sys; do
        mount -o bind /$dir $CHROOT_DIR/$dir
    done
    [ -z "$EXT_DIR" ] || mount -o bind $EXT_DIR $CHROOT_DIR/mnt
    for item in $(cat $CHROOT_SERVICES_LIST); do
        chroot $CHROOT_DIR /etc/init.d/$item start
    done
stop() {
    if [ $MountedDirCount -eq 0 ]; then
        echo "Chroot'ed services seems to be already stopped, exiting..."
        exit 1
    fi
    echo "Stopping chroot'ed Debian services..."
        chroot $CHROOT_DIR /etc/init.d/$item stop
        sleep 2
    done
    umount /opt/debian/dev/pts
    mount | grep $CHROOT_DIR | awk '{print $3}' | xargs umount -l
restart() {
        echo "Chroot'ed services seems to be already stopped"
        start
    else
            sleep 2
        done
        echo "Restarting chroot'ed Debian services..."
        done
        done
    fi
enter() {
    mount -o bind /dev/ /opt/debian/dev/
    mount -o bind /dev/pts /opt/debian/dev/pts
    mount -o bind /proc/ /opt/debian/proc/
    mount -o bind /sys/ /opt/debian/sys/
    chroot /opt/debian /bin/bash
status() {
        echo "Chroot'ed services running..."
    else
        echo "Chroot'ed services not running!"
    fi
case "$1" in
start)
    start
stop)
    stop
restart)
    restart
enter)
    enter
status)
    status
    echo "Usage: (start|stop|restart|enter|status)"
    exit 1
esac
echo Done.
exit 0
EOF
chmod 755 /opt/etc/init.d/S99debian
4) change in /opt/etc/init.d/S99debian
to
CHROOT_DIR=/tmp/mnt/asus/entware/debian
/tmp/mnt/asus - mount disk
5)
touch /opt/etc/chroot-services.list
ln -s /opt/etc/init.d/S99debian /opt/bin/debian
6)
7) debian enter
8) apt update && apt upgrade -y
9) dpkg-reconfigure tzdata
10) apt-get install -y locales
11)
echo en_US UTF-8 >> /etc/locale.gen
locale-gen
12) apt install wget
NEXTCLOUD
13)
apt install -y apache2 apache2-utils
nano /etc/apache2/ports.conf
change port to 81 and 444
service apache2 start
apache2 -v
chown www-data:www-data /var/www/html/ -R
nano /etc/apache2/conf-available/servername.conf
write "ServerName localhost"
a2enconf servername.conf
service apache2 reload
apache2ctl -t
apt -y install mariadb-server mariadb-client
service mariadb start
mysql_secure_installation
set root password "vrxzqjmfnwlvanhvebbj"
mariadb -u root
type "exit"
mariadb --version
apt -y install php7.4 libapache2-mod-php7.4 php7.4-mysql php-common php7.4-cli php7.4-common php7.4-json php7.4-opcache php7.4-readline
a2enmod php7.4
service apache2 restart
php --version
echo "<?php phpinfo(); ?>" > /var/www/html/info.php
open in browser http://192.168.1.1:81/info.php
a2dismod php7.4
apt install php7.4-fpm
a2enmod proxy_fcgi setenvif
a2enconf php7.4-fpm
service php7.4-fpm start
rm /var/www/html/info.php
wget https://download.nextcloud.com/server/releases/nextcloud-23.0.0.zip
apt -y install unzip
unzip nextcloud-23.0.0.zip -d /var/www/
chown www-data:www-data /var/www/nextcloud/ -R
rm -rf nextcloud-23.0.0.zip
mysql
create database nextcloud;
create user nextclouduser@localhost identified by 'imepoutzpanqhzjuvtuq';
grant all privileges on nextcloud.* to nextclouduser@localhost identified by 'imepoutzpanqhzjuvtuq';
flush privileges;
exit;
mkdir /etc/apache2/ssl
cd /etc/apache2/ssl
openssl genrsa -out nextcloud.key 2048
openssl req -x509 -new -key nextcloud.key -days 36500 -out nextcloud.crt
nano /etc/apache2/sites-available/nextcloud.conf
write this text
<VirtualHost *:444>
        Protocols h2 http/1.1
        DocumentRoot "/var/www/nextcloud"
        ServerName 192.168.1.1
        ErrorLog ${APACHE_LOG_DIR}/nextcloud.error
        CustomLog ${APACHE_LOG_DIR}/nextcloud.access combined
        SSLEngine on
        SSLProtocol all -SSLv2
        SSLCertificateFile     /etc/apache2/ssl/nextcloud.crt
        SSLCertificateKeyFile  /etc/apache2/ssl/nextcloud.key
        Header always set Strict-Transport-Security: "max-age=31536000; includeSubdomains"
        <Directory /var/www/nextcloud/>
            Require all granted
            Options FollowSymlinks MultiViews
            AllowOverride All
            <IfModule mod_dav.c>
                Dav off
            </IfModule>
            SetEnv HOME /var/www/nextcloud
            SetEnv HTTP_HOME /var/www/nextcloud
            Satisfy Any
         </Directory>
</VirtualHost>
a2ensite nextcloud.conf
a2enmod rewrite headers env dir mime setenvif ssl
apache2ctl -t
apt -y install php-imagick php7.4-common php7.4-mysql php7.4-fpm php7.4-gd php7.4-json php7.4-curl php7.4-zip php7.4-xml php7.4-mbstring php7.4-bz2 php7.4-intl php7.4-bcmath php7.4-gmp
apt -y install libmagickcore-6.q16-6-extra php-imagick imagemagick
mkdir /var/www/nextcloud-data
chown www-data:www-data /var/www/nextcloud-data -R
cat /etc/php/7.4/fpm/php.ini | grep upload_max_filesize
sed -i 's/upload_max_filesize = 2M/upload_max_filesize = 102400M/g' /etc/php/7.4/fpm/php.ini
service php7.4-fpm restart
cat /etc/php/7.4/fpm/php.ini | grep post_max_size
sed -i 's/post_max_size = 8M/post_max_size = 128G/g' /etc/php/7.4/fpm/php.ini
cat /etc/php/7.4/fpm/php.ini | grep max_input_time
sed -i 's/max_input_time = 60/max_input_time = 36000/g' /etc/php/7.4/fpm/php.ini
cat /etc/php/7.4/fpm/php.ini | grep max_execution_time
sed -i 's/max_execution_time = 30/max_execution_time = 36000/g' /etc/php/7.4/fpm/php.ini
a2enmod http2
a2dismod php7.4
a2dismod mpm_prefork
a2dismod mpm_worker
a2enmod mpm_event proxy_fcgi setenvif
apt -y install php7.4-fpm
a2enconf php7.4-fpm
open in browser https://192.168.1.1:444/
admin
sobylngtqdgwxvdmiqcj
nextclouduser
nextcloud
localhost
11) exit chroot
nano /opt/etc/chroot-services.list
write
apache2
mariadb
php7.4-fpm
12) start
debian start
13) stop
debian stop
You can simply enable the swap file (10GB recommended if you'll be using other amtm supported scripts) by using amtm (via ssh) instead. ;)
For people who are not highly experienced in this matter, would anyone care to explain what all this means in practical terms?
What's the router performance once all this is installed, how does Nextcloud work?
I've read in the forum the router hardware is totally inadequate for such tasks.
Generally speaking, if you don't know what/how it can benefit you (did you read their websites?), you don't need it.
On an RT-AC86U? Isn't this likely to cook the CPU - I had a fan on mine just to have it working as a router! *If I were using NextCloud for its intended purpose, then it's a bit of a stretch on a decent SBC, let alone a router!
It's a great tool but even with all my enthusiasm to install Linux on a toaster, I don't see this as realistic.
Hence my question on the practicality of the code above. Genuine curiosity.
I'm trying to install Debian Bulleyes on my Asus XT8 but I'm stuck at step 3
After issuing the following 2 commands:-
mount -i -o remount,exec,dev /tmp/mnt/sda2
They return:-
W: Cannot find binary for checking sha256 checksums, falling back to sha1
W: Cannot check Release signature; keyring file not available /usr/share/keyrings/debian-archive-keyring.gpg
E: Invalid Release file, no entry for main/binary-arm64/Packages
I tried replacing arm64 with armhf but the result is the same.
Any idea? I'm out of cards now :(
please run
df -h
copy here
Holy...your light speed reply scared the crap out of me. Never expected that at all. Greatly appreciated :)
Here it is:-
Filesystem                Size      Used Available Use% Mounted on
/dev/root                54.5M     54.5M         0 100% /
devtmpfs                249.0M         0    249.0M   0% /dev
tmpfs                   249.1M    408.0K    248.7M   0% /var
tmpfs                   249.1M      1.8M    247.2M   1% /tmp/mnt
ubi1:data                 4.5M     76.0K      4.1M   2% /data
/dev/mtdblock9           47.0M      6.6M     40.4M  14% /jffs
/dev/sda2               907.0G    208.8M    860.7G   0% /tmp/mnt/sda2
After retrieving the packages a while...
I: Retrieving zlib1g 1:1.2.11.dfsg-2+deb11u1
I: Validating zlib1g 1:1.2.11.dfsg-2+deb11u1
I: Chosen extractor for .deb packages: ar
I: Extracting libacl1...
E: Extracting .//var/cache/apt/archives/libacl1_2.2.53-10_arm64.deb requires the xzcat command, which is not available
What should I do next? And where should I extract them to? A detailed commands breakdown here would be great to newbie like me :(
I tried to ignore this error by proceeding to the next few steps (mv /opt/etc/init.d/S99debian /opt/etc/, and configure S99debian), of course it doesn't work.
need install xzcat
opkg list | grep xzcat
opkg install xz
Sorry it was too late for me last night.
asus@ZenWiFi_XT8-6410:/tmp/home/root# opkg list | grep xzcat
xz - 5.2.5-3 - Contains: xz  lzcat lzma unlzma unxz xzcat
wayneww@ZenWiFi_XT8-6410:/tmp/home/root# opkg install xz
Package xz (5.2.5-3) installed in root is up to date.
xz-utils had been installed too:
opkg install xz-utils
Package xz-utils (5.2.5-3) installed in root is up to date.
And the error still persists :(
here the same problem
but all works
try run
xzcat
MastermixStudios@GT-AX11000-A2B0:/mnt/JFFS# xzcat
bash: xzcat: command not found
tested on asus ac86u
I: Extracting adduser...
I: Extracting apt...
I: Extracting libapt-pkg6.0...
but all works
try run
xzcat
Yes, I tried google around and found those pages too.
Running xzcat gives me this error:
asus@ZenWiFi_XT8-6410:/tmp/home/root# xzcat
-sh: xzcat: not found
on may router
admin@asus:/tmp/home/root# xzcat
xzcat: compressed data not read from terminal, use -f to force it
admin@asus:/tmp/home/root# which xzcat
/opt/bin/xzcat
run this commnad
opkg update
print out here
admin@asus:/tmp/mnt/asus/entware/bin# ls -la xzcat
lrwxrwxrwx    1 admin    root            16 Jun 21 09:58 xzcat -> /opt/bin/busybox
xzcat - its symlink to busybox
why you dont have - strange
opkg http://bin.entware.net/aarch64-k3.10/
xz and xz-utils - dosnt have xzcat
run this commnad
opkg update
print out here
asus@ZenWiFi_XT8-6410:/tmp/home/root# opkg update
Downloading https://bin.entware.net/armv7sf-k3.2/Packages.gz
Updated list of available packages in /opt/var/opkg-lists/entware
asus@ZenWiFi_XT8-6410:/tmp/mnt/sda2/entware# cd bin
asus@ZenWiFi_XT8-6410:/tmp/mnt/sda2/entware/bin# ls -la xzcat
ls: xzcat: No such file or directory
o_Oo_Oo_O
