ASUS RT-AC86U Firmware version 3.0.0.4.384_81049
OzarkEdge
Part of the Furniture
WebUI is offering this 86U upgrade:
- Release Note -
Security fix:
- Fixed a DDoS vulnerability. Thanks for Altin Thartori's contribution.
Bug fix:
- Fixed web control interface login problem. (new since 81039)
- Fixed Network map clist list issues. (new since 81039)
- Fixed block internet access problem when clients connected to AiMesh node. (new since 81039)
- Fixed Samba server compatibility issue.
- Fixed OpenVPN related bugs.
- Fixed schedule reboot bugs.
- Improved AiMesh compatibility.
- Improved system stability.
Edit: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AC86U/FW_RT_AC86U_300438481049.zip
Edit: https://www.asus.com/us/Networking/RT-AC86U/HelpDesk_BIOS/
OE
Hope this one sticks? :)
gui is more responsive for me, ram usage is the same. Aimesh is running fine. ftp is back to 100Mbps after being limited to less than 70 for sometime. I'm running an 86u as a main with a 68u as a node with a Hdd media attached. for a casual user like me this update is really good and very stable.
now gui is work fast and smoth, no cpu spike
THX Asus
Deployed this after dirty flashing Merlin's latest a few days ago. Did a factory reset / init. No issues so far.
WLCEVENTD errors are spamming the log.
I upgrade my 2xRT-AC86U AiMesh, removed the remote node to reset it, webUI Restore w/Initialize the router, configured the router (no Smart Connect), added the remote node, and have been humming along just fine so far. I did not have to cycle power on my cable modem... that was unusual.
I have these events recorded in the log since bringing in my mobile from roaming around the yard and setting it aside to sleep:
Sep 5 17:04:20 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth5: Disassoc 90:C7:D8:90:85:59, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Sep 5 17:04:22 wlceventd: WLCEVENTD wlceventd_proc_event(420): eth5: Auth 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
Sep 5 17:04:22 wlceventd: WLCEVENTD wlceventd_proc_event(430): eth5: ReAssoc 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
Sep 5 17:06:52 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth5: Disassoc 90:C7:D8:90:85:59, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Sep 5 17:06:52 roamast: eth5: disconnect weak signal strength station [90:c7:d8:90:85:59]
Sep 5 17:06:52 roamast: eth5: remove client [90:c7:d8:90:85:59] from monitor list
Sep 5 17:07:05 wlceventd: WLCEVENTD wlceventd_proc_event(420): eth5: Auth 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
Sep 5 17:07:05 wlceventd: WLCEVENTD wlceventd_proc_event(430): eth5: ReAssoc 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
Sep 5 17:15:49 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth5: Disassoc 90:C7:D8:90:85:59, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Sep 5 17:15:49 roamast: eth5: disconnect weak signal strength station [90:c7:d8:90:85:59]
Sep 5 17:15:49 roamast: eth5: remove client [90:c7:d8:90:85:59] from monitor list
Sep 5 17:16:16 wlceventd: WLCEVENTD wlceventd_proc_event(420): eth5: Auth 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
Sep 5 17:16:16 wlceventd: WLCEVENTD wlceventd_proc_event(449): eth5: Assoc 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
Sep 5 17:16:42 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth5: Disassoc 90:C7:D8:90:85:59, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Sep 5 17:16:42 roamast: eth5: disconnect weak signal strength station [90:c7:d8:90:85:59]
Sep 5 17:16:42 roamast: eth5: remove client [90:c7:d8:90:85:59] from monitor list
Sep 5 17:19:12 wlceventd: WLCEVENTD wlceventd_proc_event(420): eth5: Auth 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
Sep 5 17:19:12 wlceventd: WLCEVENTD wlceventd_proc_event(449): eth5: Assoc 90:C7:D8:90:85:59, status: 0, reason: d11 RC reserved (0)
OE
ASUS must fire their Firmware Development and Engineering Team. Is this time to move to Netgear?
You should start your own topic to discuss this with other users.
OE
My initial impression is that this might have solved some irritating problems for me with AiMesh.
Probably too early to be certain but it "feels" better.
same for me.
I see continous this for my 68u node
Sep  6 06:45:11 wlceventd: WLCEVENTD wlceventd_proc_event(449): eth5: Assoc 2C:xx:A1:xx:69:xx, status: 0, reason: d11 RC reserved (0)
Sep  6 06:45:19 wlceventd: WLCEVENTD wlceventd_proc_event(386): eth5: Deauth_ind 2C:xx:A1:xx:69:xx, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Sep  6 06:45:21 wlceventd: WLCEVENTD wlceventd_proc_event(420): eth5: Auth 2C:xx:A1:xx:69:xx, status: 0, reason: d11 RC reserved (0)
Sep  6 06:45:21 wlceventd: WLCEVENTD wlceventd_proc_event(449): eth5: Assoc 2C:xx:A1:xx:69:xx, status: 0, reason: d11 RC reserved (0)
Sep  6 06:45:23 wlceventd: WLCEVENTD wlceventd_proc_event(401): eth5: Disassoc 2C:xx:A1:xx:69:xx, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
and in wireles log my node is not authorized in 2,4GHz band
idx MAC               Associated Authorized    RSSI PHY PSM SGI STBC MUBF NSS Tx rate Rx rate Connect Time
    2C:xx:A1:xx:69:xx Yes                      0dBm ac  No  Yes Yes  No     3      1M         00:00:02
same for me.
Try resetting the node and readding it. There's been a large jump in version, there might have been changes to AiMesh as well requiring re-adding nodes.
i jump from 81039, and with 81039 i have no problem with my node.
strange....
my node end of mac is xx:40, but in log i see xx.41
its normal ?
readding node not help, now 2,4GHz on node is not avaible....only node restart will help for some time
for me AIMesh in this release is not stable
Upgraded via "firmware upgrade" button within UI...no problems so far. CPU usage seems normal and the Web UI works as expected.
Running 81049 since announced in this forum on my 2 x RT-AC86u AiMesh and now the AiMesh node is offline for the second time.
