ASUS RT-AC86U last Merlin fw. 384.19 upload speed problem
Saiyan10
Hi, i have bought this router recently, and i have 600 MB upload /download speed on my network.
When I test my connection in stock firmware I get full upload/download speed, but, when I have installed Merlon fw 384.19 and i make a test, the upload speed is limited to 30 (with ethernet and wifi connection).
If I install the stock fw I recover the connection speed.
I have not configure anything.
Can anyone help me with this problem?
thank you.
Did you do a Hard Factory Reset after flashing 384.19?
ASUS router Hard Factory Reset - Method 2
1. Turn the router off.
2. Press and hold the "WPS" button and turn the router on.
3. Power light is on (keep holding the WPS button).
4. Release the WPS button after the power light is off.
5. Reboot your router by manually pressing the power button off then on.
