Asus Rt-AC86u
NicFP98
I got an firmware update on my router which was 3.0.0.4.384.81992 and after that it seemed to not work properly. It’s an AIMESH node and what I also seen is that it’s only the 5GHZ that’s doesn’t work. I put all my devices to the 2.4 and they worked fine, switched to the 5GHZ and they dont seem to connect. Anyone know what may be wrong?
I posted about a node connection issue with 81992:
It might help if you add your issue to that thread since that thread discusses 81992.
I returned to 81858 configured as noted in my install notes.
OE
