I have a Merlin 384.5 installed. All working like a charm. Recently I changed some settings in DHCP server menu, added some manually assigned IPs etc. After applying the changes, the DHCP server settings tab seems to be broken, when clicking on the DHCP server menu, I get only that frame, the rest of the screen is gone, the manually assigned ip list is empty and I am unable to change any settings, the Apply button does not work.
I tried everything I could think of, incl. uploading new firmware. The last thing to try would be a factory reset which obviously I'd like to avoid.
Any ideas?
Thanks!
Any ideas?
Thanks!
