Asus RT-AC87U FW 378.55_0: Changing mac = fail + IEEE 802.11h support enable = fail
TSE
Hi
I can't change the WAN-MAC-Address:
After applying the Gui shows the new mac, but it isn't changed on the WAN interface.
I can't enable IEEE 802.11h support for 5G-WLAN:
After appllying, the Gui shows "disabled"
I can't find any log entries.
Thx, for your help.
For the MAC cloning to work I suspect you need to restart your router, power cycle it to be safe.
I restarted the router but it doesn't change the MAC-Address.
I found this on the Asus web page (Beta Japan only firmware):
Beta Version 3.0.0.4.378.7410
ASUS RT-AC87U Firmware version 3.0.0.4.378.7410
- Release Note -
[For Japan Only]
Security fixes
- Fixed MAC clone abnormal issue
Both are known issues in Asus's code, and have been fixed upstream by them. In the second case, they simply removed that setting as it doesn't work.
How can I temporary fix this problem on my RT-AC87U and FW 378.55? Can I setup MAC address for WAN by shell scripts in JFFS?
P.S. On Asus firmware 3.0.0.4.378.7410 MAC clone working fine.
They simply removed that? I thought I have to use this option in Europe!
They removed the ability to change it. I assume it automatically gets enabled in regions that are DFS-enabled if they did the same thing they are doing with Broadcom-based radios.
Thx.
Is there a workaround for the mac issue?
Simplest is probably to revert back to 378.54 for now if your ISP requires MAC cloning.
Any chance that mac cloning issue is fixed for RT-AC87U in recently released Asuswrt-Merlin 378.56?
They are both based on 9177, so it should be fixed.
