Asus RT-AC88U Dual WAN - LAN port 5,6,7,8 selection
krustycat
Is there anyway to select LAN ports from 5-8 when doing Dual WAN?
My LAN ports 1-4 are fried and so is the WAN port.
Luckily, I was able to use the USB port, great feature, thank you.
But, I wonder if LAN ports from 5-8 are also available somehow as I couldn't see an option for it.
Thank you very much.
Probably not available because they are on a separate switch.
Got it, thank you, makes sense, I should have known better, I am now reading about the second chip, it seems that eventually I will have no choice but to buy a new router.
Why? Buy a new switch instead. Much cheaper.
