Release ASUS RT-AX1800S V2 Firmware version 3.0.0.4.388_33965 (2025/10/22)
fruitcornbread
Version 3.0.0.4.388_33965
29.68 MB
2025/10/22
- Enhanced system stability.
- Enhanced input validation and refactored legacy string handling routines to ensure robust memory management.
- Implemented comprehensive validation and expanded command filtering in the web history API.
- Strengthened input validation and directory handling in the VPN configuration upload interface.
- Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
Please unzip the firmware file, and then verify the checksum.
FW SHA-256 : 86f0d4f9725a526399e934ac82e40b7f51c696dde8a40fccab9c9af781b9c021
It is also called RT-AX54HP V2 or RT-AX1800HP V2 in other regions so go check their respective websites (they use the same firmware). RT-AX57M / RT-AX3000S uses identical hardware and has the same firmware update (same hash) as well, but with 160MHz unlocked on 5GHz.
RT-AX1800S V2 ZIP SHA-256 : 6F63D0D5134558C8799E47147E09D79FB1FF96CCB9F6CBA2E2BB177B598FC00F
Download RT-AX1800S V2: https://dlcdnets.asus.com/pub/ASUS/..._AX1800S_V2_300438833965.zip?model=RT-AX1800S
RT-AX54HP V2 ZIP SHA-256 : EA59B96155335B4F8AAA772B1AB11138BA97AAF82BF694B69CE0ACBE44044924
Download RT-AX54HP V2: https://dlcdnets.asus.com/pub/ASUS/...RT_AX54HP_V2_300438833965.zip?model=RT-AX54HP
RT-AX1800HP V2 ZIP SHA-256 : 19DDA0EA996C2343EAB779CCF40EBCCFBEDF74C64A5B6F1AB662F02B341E0C58
Download RT-AX1800HP V2: https://dlcdnets.asus.com/pub/ASUS/...X1800HP_V2_300438833965.zip?model=RT-AX1800HP
RT-AX57M ZIP SHA-256 : 3ED1C5036FC0A5AFDE80510C5EB81FEED91C865C85F7FF884231DB9228843447
Download RT-AX57M: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX57M/FW_RT_AX57M_300438833965.zip?model=RT-AX57M
RT-AX3000S ZIP SHA-256 : BE6550A46A95DED8BEE70C74F11506EC602841FF074D0A002DB845AF9EA545AF
Download RT-AX3000S: https://dlcdnets.asus.com/pub/ASUS/..._RT_AX3000S_300438833965.zip?model=RT-AX3000S
Edit: ASUS renamed the files to include "V2" and reuploaded on Oct 22. Date, ZIP hash, release notes and links were changed and updated. FW hash remains the same.
ASUS renamed the files to include "V2" and reuploaded on Oct 22. Date, ZIP hash, release notes and links were changed. FW hash remains the same.
