Release ASUS RT-AX1800S V2 Firmware version 3.0.0.4.388_34015 (2026/03/24)
fruitcornbread
Version 3.0.0.4.388_34015
29.63 MB
2026/03/24
Security Fixes
- Enhanced input validation and protection to reduce the risk of command injection and SQL injection.
- Hardened environment variable handling.
- Hardened protections around specific logging/command composition flows to reduce potential injection risks.
- Patched a command injection risk in a specific network diagnostic function.
We recommend upgrading to this version to maintain best protection.
Please unzip the firmware file, and then verify the checksum.
FW SHA-256 : 60636DE467480B88DE9D4B62922818D1BEEFFA2D08CE0771C1E4632603783875
It is also called RT-AX54HP V2 or RT-AX1800HP V2 in other regions so go check their respective websites (they use the same firmware). RT-AX57M / RT-AX3000S uses identical hardware and has the same firmware update (same hash) as well, but with 160MHz unlocked on 5GHz.
RT-AX1800S V2 ZIP SHA-256 : E7F0EED637FAC8FEB54EB6C77C25A0AA977CFEDFC9C8D5E9CA93138489FD3DFB
Download RT-AX1800S V2: https://dlcdnets.asus.com/pub/ASUS/...-AX1800S_V2_300438834015.zip?model=RT-AX1800S
(You will need to copy the link and paste it in a browser for the link above to work.)
RT-AX54HP V2 ZIP SHA-256 : EA0E1C6D707CD07D6BA712E63DA13296CDED31CEE46A759B2AD3BD79ABF54E3E
Download RT-AX54HP V2: https://dlcdnets.asus.com/pub/ASUS/...RT-AX54HP_V2_300438834015.zip?model=RT-AX54HP
RT-AX1800HP V2 ZIP SHA-256 : 2A7449D5BEC277BA64F5B92FF515DCEDD2198E709DE18781C7EF8254F05F2FBC
Download RT-AX1800HP V2: https://dlcdnets.asus.com/pub/ASUS/...-1800HP_V2_300438834015.zip?model=RT-AX1800HP
RT-AX57M ZIP SHA-256 : 9A3A2D704FEDC3BB1820B96B08BC019DBB36FEF341DDC3FAE07B324459A09017
Download RT-AX57M: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX57M/FW_RT-AX57M_300438834015.zip?model=RT-AX57M
RT-AX3000S ZIP SHA-256 : 182D7D773D776E4CC7BF2277DA95FF59CC9AA798A87F569908B7FFDD464D4444
Download RT-AX3000S: https://dlcdnets.asus.com/pub/ASUS/..._RT-AX3000S_300438834015.zip?model=RT-AX3000S
