Release ASUS RT-AX52 Firmware version 3.0.0.4.388_33950 (2025/08/25)
fruitcornbread
Version 3.0.0.4.388_33950
RT-AX52 - 25.23 MB
RT-AX52 Pro - 25.25 MB
2025/08/25
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
Please unzip the firmware file, and then verify the checksum. RT-AX52 Pro uses identical hardware and has the same firmware update (same hash) as well, but with 160MHz unlocked on 5GHz.
FW SHA-256 : eb3e104677dab6048f6de1a2c1ec5ffe8b8c556d5ce16c28de05d6d11991a449
RT-AX52 ZIP SHA-256 : A5EF190C4ED7C47A68C2BC1ED68FD77912A8D17EA4B988295B77310BB2000DD2
Download RT-AX52: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX52/FW_RT_AX52_300438833950.zip?model=RT-AX52
RT-AX52 Pro ZIP SHA-256 : 86DAD3425EA7DFF9371405A887FDB5346417BC0B78F579274AFAEEDF75A8B808
Download RT-AX52 Pro: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX52 Pro/FW_RT_AX52_Pro_300438833950.zip?model=RT-AX52 Pro
