Release ASUS RT-AX5400 Firmware version 3.0.0.4.388_25192 (2025/08/27)
fruitcornbread
Version 3.0.0.4.388_25192
48.25 MB
2025/08/27
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
Bug Fixes:
- Fixed abnormal client list.
- Fixed abnormal GUI behavior of Wireguard VPN.
- Fixed USB internet backup conflict with main WAN.
- Fixed abnormal WAN detection while AiDetection is enabled.
- Improved AdGuard DNS GUI issues.
- Fixed IPv6 related issues.
- Improved USB tether compatibility for pixel phones.
ZIP SHA-256 : 5D4C071903C61762961B5B6381BF7D2A02A1A94F2F824EEACA825C2E82A37E62
FW SHA-256 : aab1ca0fecf8af97a603811a9564236f66daca928c92e3bae33ef965ef4c4229
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX5400/FW_RT_AX5400_300438825192.zip?model=RT-AX5400
