Release ASUS RT-AX68U Firmware version 3.0.0.4.388_24761 (2025/08/22)
fruitcornbread
Version 3.0.0.4.388_24761
69.96 MB
2025/08/22
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
ZIP SHA-256 : A962EB0454A32C64411510B76E012BC8FAA7A6E8711DC7E44D2A9435CA89B8F8
FW SHA-256 : 5f3385be730dbc24bec8502d0c472ae9a240349c37b9e253463db6ea916009b1
Download: https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX68U/FW_RT_AX68U_300438824761.zip?model=RT-AX68U
