Asus RT-AX82u AIMesh Issue
Ripface
Hi All,
Got a bit of a weird issue with my Asus RT-AX82U Router. I wanted to extend the WiFi in the house so purchased an RT-AX52 and set it up as a mesh node. It was a bit far from the RT-AX82U so it's got a 1GB Ethernet connection and I configured that as the backhaul. It appears to be setup correctly and is showing in the AIMesh screen on the Gui .... but in this screen both routers are showing 0 clients attached. On the main Network Map screen it shows 49 clients!!
Now I don't know whether clients are connecting to the main router or the mesh node. Anyone seen this before and can suggest a fix?
Main Router is running 3004.388.9_2-gnuton1
Mesh node is running 3.0.0.4.388_33911
Cheers,
Ripface
