Do not know at this point.Is this anything to do with the WPA2/WPA3 blend not working or just IoT stuff that runs on WPA2, 2.4GHz? If you know?
Thanks.
Applied this update to my RT-AX86U (set aside as a backup router). So, will see how it functions if I ever need to use it again. Just keeping it up to date at this point. My long term observations after switching to the BE92U from the RT-AX86U have been positive overall. The main change I've observed is an overall more reliable internet connection. There were several factors involved with this, so I can't confirm if this was the RT-AX86U specifically, but I would have random connection drops and speed issues. That hasn't happened in quite a while after using the new router, but I also dropped my internet plan speed too as a test, so it could have been a combination of things.
Well for the BE92U, I can and I don't have an issue with it. The main networks are mixed, and the iOT network is WPA 2 only. When I was using the RT-AX86U. I mostly kept it to WPA2-Personal across the board.Would be good if you could report on mixed mode of WPA2/WPA3 now working properly.
I'm waiting for the RMerlin point revision fixes to be formalized.
Well, at least for the RT-AX86U, Asus specifically recommends using WPA2-Personal for best compatibility, and why they default to it. So keep that in mind, if you run into problems with mixed mode, or WPA3 in general.Well for the BE92U, I can and I don't have an issue with it. The main networks are mixed, and the iOT network is WPA 2 only. When I was using the RT-AX86U. I mostly kept it to WPA2-Personal across the board.
I realize that. I was however, just making reference to the info Asus provides in that area of settings where they have always stated that if you have issues, setting it to WPA2-Personal is recommended for best compatibility. I think because the RT-AX86U was one of their first gen WiFi 6 routers, that's why they defaulted to WPA2-Personal vs Mixed mode and made the recommendation in their info to keep it there for best compatibility. Honestly, in my set up, I think my iPhone is the only wireless device that can use WPA3, so for me, it doesn't make sense to enable it when WPA2 works fine. the BE92U defaults to mixed mode, and I've left it on as it hasn't caused issues. I don't remember if you've ever mentioned doing a factory reset after the latest firmware update to see if that resolves the issue.Mixed mode according to ASUS is supposed to auto-select based on the client when in WPA2/WPA3. It should be a no-brainer but they broke it and now it needs fixing.
So far seems to be about the same
I have a different issue I've been keeping an eye on from time to time, and thankfully right now it looks like some LEDs have simply failed. The status lights on the modem that are blue for a solid Docsis 3.1 connection have really dimmed over time where as the amber and green ones are still full brightness, my only concern here is early signs of a power issue with the modem, but the connection is stable so I haven't paid much attention to it. I did go into the modem settings today and set the lights to turn off under normal conditions so they only light up when issues . I have warranty coverage on the modem until November of 2026 in case something happens that I need it for. Today was the first time I power cycled the modem in quite a few months and that was just to reset it for the other router. So things have been overall stable here. Was just concerned about the dim LEDs being a sign of bigger issues to come, but so far, doesn't seem to be the case.Of course. You already had what you need.
Good to know. The modem. is in the direct path of a big floor oscillating fan as well, that keeps the air circulating in the living room, and I have checked to make sure it hasn't overheated as the S33 (my modem) is known to run hot. Also, in this case, the modem stays warm, but never hot. So no heat issues here either, which is also good. Cosmetic I can deal with. That's why turned the lights fully off unless of problems. Don't need them on at all. Thanks for confirming it was nothing to worry about long term. I had reached out to the surfboard community earlier today as well.No, this is common for white/blue LEDs. Cosmetic issue.
Thanks for your help. One more thing, does this white / blue LED issue involve burning out completely ? That seems to have also been the case here and cause, or partial cause of the dimming. (only speculating here by looking in the vents.). LEDs are strange, I have things with Blue LEDs that still look as new years later, and then other things like the modem that have dimmed, or gone out / flicker.The white/blue LEDs dimming is more chemistry than temperature related.
Welcome To SNBForums
