ASUS RT-AX86U / Open VPN
RebelAngel
My question is about a setting that's maybe not only specific for the router I own. Anyways I wonder, when I'm using OpenVPN if there's a chance to not end up in the IP-range 10.x.x.x but 192.168.x.x because certain things don't work that way...
bbunge
Part of the Furniture
You can change the VPN subnet and netmask. But not to the same used in the LAN.
For me the default values work just fine even when remoting into a client connected to the server via OpenVPN.
sipankh
Well, glad to read you all have no issues with OpenVPN setup on this Asus rt but I sure do ever since I upgraded it to the AsusWrt Merlin 386.2_6. Server is supposedly running and syslog captures any changes I do to the config but it is not responding to any attempts to connect by the clients. I didn't test with the firewall being off, but on my AC68U I never had to turn off the firewall in order to have OpenVPN svr running. Any tip is appreciated in advance.
