pink.skyline
Hello, my first post here. Let me know if I can provide more details or something.
ASUS RT-AX86U
386.5_2
My problem is the following:
I'm experimenting with some different setups within the 'VPN > VPN Client' menu. I was configuring NordVPN as one of the clients following the tutorial on their site.
I was switching the 'Client State' on and off a whole lot because I was troubleshooting some specific issue I had (outside of scope of this question).
That's when at one of such 'On'-presses, after initial loading screen, the whole router got slowed into a crawl.
Everything got extremely slow. I could not get to the dashboard getting 'connection reset' errors, the quality of the internet call a network client was in progressively degraded into nonexistent.
I could not get into the router anymore since my HTTP dashboard was off and HTTPS was too much too ask from the router. I restarted it. Auto-start of the VPN ensured I was locked out from my router for good.
I had barely a few seconds after the boot when the router dash would work then it would all freeze again. I had to reset the entire thing and upload me backup config.
Button in question:
This whole thing happened twice. Both times I pressed the 'Off' button to enable the config (I don't think I really changed config either, it was just a Off-On cycle).
Either way, this should not happen with any kind of bogus config (if there were any), this feels more sort of memory-leak/fork-bombing or some resource exhaustion scenario.
I could not get to any performance stats to confirm any of it.
Interestingly, there is a piece describing this situation in a different menu in a different VPN (Mullvad) guide for merlin located here: https://mullvad.net/en/help/asus-merlin-and-mullvad-vpn/
That states:
So does any of this make sense? Is this a known issue?
I'm holding my breath every time I turn the clients VPNs on at this point.
ASUS RT-AX86U
386.5_2
Button in question:
That states:
Note: Merlin firmware version 386.5_2 may fail this step and make the router inaccessible. If this happens you can install a newer firmware version or the older 386.5 instead.
