Hello, I'm new here with my router
The problem with the router is that the router disconnects from the WAN network very often, disconnects 2.4 and 5 GHz Radios, after some time it works normally and so on. Currently I am using software 3.0.0.4.386_23012 and it disconnects less often, but still too often - several times an hour. With the latest software, it happens even more often and the router would also reset, but in such a way that it could not turn on but kept resetting, only turning off the power and discharging the capacitors helped. I did a hard reset, a RAM reset and used firmware restoration to upload different versions of the software, it doesn't change anything, it just sometimes works longer or shorter. I was thinking about replacing the SPI chip with the software and uploading a new one via SVOD, or replacing the memory chip with new ones, e.g. from Samsung instead of Micron. If anyone could advise me, I would be very grateful. I will add that the temperatures of the systems on the motherboard are max 50 degrees CPU and 25-45 5 GHz system. Adds a log from the moment of disconnection, marked in red. Regards
